using AcadApp = Autodesk.AutoCAD.ApplicationServices.Application;
string acVer = AcadApp.GetSystemVariable("ACADVER").ToString();
~= acVer "18.2s (LMS Tech)"
// Called Kerry in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect.
Sometimes the question is more important than the answer.
class keyThumper<T> : Lazy<T>; another Swamper
or if you want the AutoCAD build version number.
use "_VERNUM"
