.NET
AutoCAD 2013 plugin compatibility with AutoCAD 2019
1 REPLY 1
autoDeveloper
898 Views, 1 Reply
We have developed .NET plugin (64bit) for AutoCAD 2013 (.NET framework 4.0) using VS-2015.
Now Autodesk has released AutoCAD 2019 version.
Can we expect same plugin will work on AutoCAD 2019 without any rebuild or code rewrite ? Is AutoCAD 2019 binary compatible with AutoCAD 2013 ?
Thanks in advance,
PP
1 REPLY 1
_gile
in reply to: autoDeveloper
If the plugin uses only the APIs that didn't change between 2013 to 2019 (and very few changed), the same assembly might work with AutoCAD 2019.
The only real break of compatibility with AutoCAD .NET occured with the 2013 version and the split of acad.exe into acad.exe and accore.dll.
The simplest way to know if there's a compatibility issue with your plugin is to to load it in AutoCAD 2019 and test if it works as expected.
Gilles Chanteau
GileCAD
GitHub
Forma Design Contest
AutoCAD Beta
