.NET
API CANTCurves & CANTCriticalStation
4 REPLIES 4
gabriel_sit
340 Views, 4 Replies
I cant access CANTCurves in an Alignment. I get messages like : "Alignment cannot be opened for write successfully."
When I try : "trans.GetObject(al.ObjectId, _AcDb.OpenMode.ForWrite)" I get "Autodesk.AutoCAD.Runtime.Exception: eLockViolation"
When I try :"myAlignment.UpgradeOpen()" I get "eInvalidOpenState"
How can I access cant informations of an alignment?
public ArrayList TEST_cant(Alignment al)
   ArrayList lstTest = new ArrayList();
   _AcAp.Document doc = _AcAp.Application.DocumentManager.MdiActiveDocument;
   _AcDb.Database db = doc.Database;
   using (_AcDb.Transaction trans = db.TransactionManager.StartTransaction())
      //Alignment al_bis = trans.GetObject(al.ObjectId, _AcDb.OpenMode.ForWrite) as _AcCDb::Alignment;
//Autodesk.AutoCAD.Runtime.Exception: eLockViolation
      ArrayList lstStations = GetStartStations(al);
      al.UpgradeOpen(); // eInvalidOpenState
      CANTCurveCollection cantCurveCollection = al.CANTCurves; //Alignment cannot be opened for write successfully.
      MessageBox.Show("CANTcurveCollection retrived");
      foreach (CANTCurve CANTcurve in cantCurveCollection)
         lstTest.Add("CANTcurve");
         lstTest.Add(CANTcurve.StartStation);
         MessageBox.Show(CANTcurve.Name);
         foreach (CANTCriticalStation CANTcrtclStn in CANTcurve.CANTCriticalStations)
             lstTest.Add("CANTcrtclSTN");
             lstTest.Add(CANTcrtclStn.CANTCurveName);
             MessageBox.Show(CANTcrtclStn.CANTCurveName);
      al.Update();
      trans.Commit();
   return lstTest;
Labels (2)
4 REPLIES 4
Is your code being run from a command method, or from a button click handler on a dialog, palette, or other UI?
The problem is most likely that you are running your code from the latter, and you are not locking the document before trying to access it.
Document doc = Application.DocumentManager.MdiActiveDocument
using(doc.LockDocument())
  // Ok to access document contents here
My code is run from a command method that opens a windows form from which I can select an alignment and a method. I do this to test methods that takes an alignment as argument and check if they are working.
A lot of them are working fine like :
public ArrayList GetEntities(Alignment al)
   ArrayList lstEntity = new ArrayList();
   foreach (_AcCDb::AlignmentEntity entity in al.Entities)
      lstEntity.Add(entity);
   return lstEntity;
I tried a bit messing around with :
but I get the same errors.
You don't mention how the Windows Form is shown. It can be shown as a modal window or a modeless window. Also as far as your attempts to use the lock document code you need to show the entire code not just one line.
I think I have modeless forms as I am able to draw in the model space.
As for the document locking I tried, 2 position of "using (doc.LockDocument())" inside the method to get ant information, each time I tried with or without ".UpgradeOpen()".
public ArrayList TEST_cant_CANTCurve(Alignment al)               //not ok
    using (doc.LockDocument()) ;
            //using (doc.LockDocument()) ;
            //al.UpgradeOpen();        //Autodesk.AutoCAD.Runtime.Exception: eInvalidOpenState
Forma Design Contest
