Adding property in general section
arpeet.shah
arpeet.shah
Community Visitor
Community Visitor
Hello Folks, Can we modify the "Properties Palette functionality" of AutoCAD to add a custom property in the General section for each entity using AutoCAD .Net api ?
I am facing challenges to add a property in the General section so that I can fetch it in Navvisworks and forge. Please let me know if it is possible and if we can add a property in the General section. Below is the reference image for you to understand the exact location where I wish to add custom field in the pallet.
Thanks in advance.
Ed__Jobe
See this topic.
https://forums.autodesk.com/t5/net/how-to-create-custom-prop-in-properties-palettes-and-assign-to/m-...
Ed
How to post your code.
arpeet.shah
Community Visitor
Community Visitor
Hello @Ed__Jobe , the solution that you have provided above doesn't provide us the desired results.
We are trying to add custom properties in the general section of the Property pallet.
For a clear view, we have tried the following solutions as well:
https://through-the-interface.typepad.com/through_the_interface/2009/03/exposing-autocads-properties...
https://www.keanw.com/2009/03/exposing-autocads-properties-palette-functionality-to-net---part-2.htm...
But somehow we are not able to build the code in this. We are looking for the similar solution in AutoCAD 2020 and above.
Ed__Jobe
The post I linked to mentioned that you can't do it without C++ to develop an *.arx file. That's what Kean did in part 1, the post you linked to. In part 2, he supplied the code for the arx project and a arx file, plus the NET code to use the arx. To compile the arx code, you need to use C++, even though the code looks similar to C#.
Ed
