Is there a way to add a function or setting which makes the Zoom go 5x faster when holding the Ctrl button while scrolling?
I've had some help making a script which allows me to have different zoom speeds for different viewports, but I would also like to easily switch between slow zoom and fast zoom, preferably by simply holding the Ctrl button.
I can't find any mouse wheel settings in CUI and it doesn't seem to be possible to do it with a LISP.
Any ideas?
oh, I like that idea a lot.
This is an interesting question, as I think you must capture the mouse scroll event, and do something.
Only question is how to intercept the regular mouse zoom and switch it for your callback.
Kean Walmsley used to mess with stuff like this, but he does not blog on .net anymore, sad IMO.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Pan speed is also f..d up in perspective mode. I haven't seen a variable in AutoCad to control that. Is it possible to adjust the pan speed aswell through the .NET API?
AFAIK, the mouse wheel zoom and pan step/increment is hard-wired and not configurable via any means.
@doaiena wrote:Pan speed is also f..d up in perspective mode. I haven't seen a variable in AutoCad to control that. Is it possible to adjust the pan speed aswell through the .NET API?
