.NET
AcCoreConsole hang at Process
9 REPLIES 9
Message 1 of 10
wesbird
1044 Views, 9 Replies
I created a LispFunction in C# to print mutiple layout out as PDF. it works fine in AutoCAD.
then I create a script (.scr) to run this LispFunction, a bat file to call AcCoreConsole and this script file, and run it from DOS command line, it also works just fine
after that, I create a C# exe, use Process to call AcCoreConsole, use the same parameter in my bat file in Process, it hang at 3rd layout, right before the line of code below:
LayoutManager.Current.CurrentLayout = layoutToPrint;
first 2 layout print out as PDF successfully.
Anybody had the same problem before?
Thank you
Wes
AutoCAD 2016, .Net 4.5.2
Windows 10 64 bit, AutoCAD (ACA, Map) 2023
9 REPLIES 9
Message 2 of 10
FRFR1426
in reply to: wesbird
Exception message?
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Message 3 of 10
wesbird
in reply to: FRFR1426
Too bad, there is no exception message. It simply timeout.
Thank you, FRFR1426
Wes
Message 4 of 10
BKSpurgeon
Hi
You say that it times out when it tries to print the third pdf.
A couple of things to try:
  1. Get rid of the other two files. Run the script file (through your c# exe)  on just the file where it was hanging - just one file.  Does it successfully print?
  2. copy one of the files three times (not the one that hangs) - and then run it - do all three files print?
    1. test1.dwg
    2. test2.dwg
    3. test3.dwg
  3. Consider the following line of code:
how is the layoutToPrint value derived?
hope this helps.
rgds
BK
Message 5 of 10
FRFR1426
BACKGROUNDPLOT at 0?
Maxence DELANNOY
Manager
http://wiip.fr
Message 6 of 10
wesbird
in reply to: BKSpurgeon
Hi, BKSpurgeon
Sorry I didnot make it very in my first post.
I did not have problem to print multiple DWG file, I have problem to print multiple layout of one DWG file.
I tried another DWG file, it hang at 4th layout.
layoutToPrint is the name of layout to print out.
Thank you
Wes
Message 7 of 10
wesbird
Hi, FRFR1426
I set BACKGROUNDPLOT to 0 in my code.
Here is the code I used to run AcCoreConsole, which I learned here or swamp. might be the trouble come from?
        public void Run_Process(string FileName, ACCResult ccr)
            using (Process process = new Process())
                process.StartInfo = CreateProcessStartInfo(FileName);
                process.Start();
                if (!process.WaitForExit(_ProcessInfo.MaxTime))
                    ccr.Status = ACCStatusCode.Timeout;
                    process.CloseMainWindow();
                    if (!process.WaitForExit(2000))
                        process.Kill();
                else
                    string output = process.StandardOutput.ReadToEnd();
                    output = output.Replace("\0", "").Replace("\r\n", "").Replace("\b", "");
                    string err = process.StandardError.ReadToEnd();
                    if (!string.IsNullOrEmpty(err))
                        output += Environment.NewLine + BPLog.ERROR_MARK + err;
                    ccr.OutPut = output;
Message 8 of 10
FRFR1426
What's _ProcessInfo.MaxTime?
Maxence DELANNOY
Manager
http://wiip.fr
Message 9 of 10
wesbird
Thank, FRFR1426
_ProcessInfo.MaxTime was 10,000, then I change to 100,000. neither works.
later yesterday, I change the code from
    process.Kill();
to
process.WaitForExit(_ProcessInfo.MaxTime);
then it works.
I'm  not good at this one. good it works.
Wes
Message 10 of 10
FRFR1426
It seems that the process you're starting is returning before the processing of the PDF is done. You should check what's happening with a tool like Process Explorer.
Anyway, a timeout of 10 000 ms (10 secondes) was definitely too short for this kind of operation.
Calling WaitForExit with a timeout has no sense if you're not checking the return value. If your calling program does not have to wait, just don't use WaitForExit.
Maxence DELANNOY
Manager
http://wiip.fr
Forma Design Contest
