Hello
Am I able to access and read and write to the file holding the variables used in the parameters-manager's palette, please. Ideally, I want to read the value held for an action-parameter, do some math using C, and write the result back to the file as a user-parameter which may be seen in the parameters-manager's palette.
Regards
Solved by Balaji_Ram. Go to Solution.
Have you tried the .Net API for accessing parmeters explained in this blog post ?
The "MGHLPARAM" should help you access parameters.
Balaji
