.NET
Accessing variables
2 REPLIES 2
cve60069
476 Views, 2 Replies
Accessing variables
cve60069
Hello
Am I able to access and read and write to the file holding the variables used in the parameters-manager's palette, please.  Ideally, I want to read the value held for an action-parameter, do some math using C, and write the result back to the file as a user-parameter which may be seen in the parameters-manager's palette.
Regards
Accessing variables
Hello
Regards
2 REPLIES 2
Balaji_Ram
in reply to: cve60069
Balaji_Ram
Have you tried the .Net API for accessing parmeters explained in this blog post ?
http://adndevblog.typepad.com/autocad/2013/01/a-simplified-net-api-for-accessing-autocad-parameters-...
The "MGHLPARAM" should help you access parameters.
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
Balaji
Balaji
cve60069
in reply to: Balaji_Ram
cve60069
Thank you.
I will read on.
Regards
Thank you.
I will read on.
Regards
AutoCAD Inside the Factory
