What's Difference between ApplicationServices & ApplicationServices.Core
Amremad
Amremad
Hi All
What's Difference between :
1. Autodesk.AutoCAD.ApplicationServices
2. Autodesk.AutoCAD.ApplicationServices.Core
i think they have the same method ?
norman.yuan
They are "namespace", not class (thus, do not have "method").
"namespace" is for organising classes. It is a bit similar to File Path with File Name: you may have 2 files with the same file name, but the contents could be different. You cannot place the 2 files in the same folder (path), instead, you place them in different folders, and refer to them with different full path/file name, when you somehow need to deal with both at the same time.
Norman Yuan
Drive CAD With Code
Amremad
sorry i missed . yes they are namespaces
but my question is :
what's the different  between the next two line
Document document1 =  Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
Document document2 = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument;
both two give me the Active Document
norman.yuan
Well, Autodesk.AutoCAD.Application.ApplicationServices.Application inherits Autodesk.AutoCAD.ApplicationServices.Core.Application.
Since ...ApplicationServices.Core.Application has the property "DocumentManager", thus ...ApplicationServices.Application automatically has the same property. Therefore,
...ApplicationServices.Core.Application.DocumentManager and ApplicationServices.Application.DocumentManager point to the same DocumentCollection object.
Norman Yuan
Drive CAD With Code
_gile
Hi
The Autodesk.AutoCAD.ApplicationServices.Application class is derived from Autodesk.AutoCAD.ApplicationServices.Core.Application one.
You can see this in Visual Studio:
or in ILSpy:
Norman was faster...
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
