draworder - an problem by select objects
jan_tappenbeck
jan_tappenbeck
hi !
i want to create a draworder-function with a subfunction to select object by layer-filter.
the function to select the elements is following:
 Public Function GetEntitiesOnLayer(layerName As String) As ObjectIdCollection
        ' http://ma22-wiki-001/eblwiki/index.php?title=Acad_(Klasse_von_EBL.Service)#GetEntitiesOnLayer
        ' Quelle: http://through-the-interface.typepad.com/through_the_interface/2008/05/finding-all-the.html
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        ' Build a filter list so that only entities
        ' on the specified layer are selected
        Dim tvs As TypedValue() = New TypedValue(0) {New TypedValue(CInt(DxfCode.LayerName), layerName)}
        Dim sf As New SelectionFilter(tvs)
        Dim psr As PromptSelectionResult = ed.SelectAll(sf)
        If psr.Status = PromptStatus.OK Then
            Return New ObjectIdCollection(psr.Value.GetObjectIds())
        Else
            Return New ObjectIdCollection()
    End Function
the draworder-main function is:
 ''' <summary>
    ''' ändern der Zeichenreihenfolge - HINTERgrund
    ''' </summary>
    ''' <param name="LayerFilter">Filter für die Layernamen</param>
    ''' <param name="Log">optional byref Log (default:= LEERSTRING)</param>
    ''' <returns>true ... ok / false ....mit Fehler</returns>
    Public Function DrawOrderChangeToButtom(ByVal LayerFilter As String, Optional ByRef Log As String = "") As Boolean
        _Editor.WriteMessage("Objekte in den Hintergrund verschieben ...")
        DrawOrderChange_Work(LayerFilter, 0, Log)
    End Function
    ''' <summary>
    ''' ändern der Zeichenreihenfolge - VORDERgrund
    ''' </summary>
    Public Function DrawOrderChangeToTop(ByVal LayerFilter As String, Optional ByRef Log As String = "") As Boolean
        _Editor.WriteMessage("Objekte in den Vordergrund verschieben ...")
        DrawOrderChange_Work(LayerFilter, 1, Log)
    End Function
    ''' <summary>
    ''' ändern der Zeichenreihenfolge - Arbeitsfunktion
    ''' </summary>
    ''' <param name="Status">0 .... 2Buttom / 1 ... 2Top</param>
    Private Function DrawOrderChange_Work(ByVal LayerFilter As String, ByVal Status As Short, Optional ByRef Log As String = "") As Boolean
        AcReInit()
        Dim Obj2Move As ObjectIdCollection = GetEntitiesOnLayer(LayerFilter)
        Dim drawOrder As New SortedList(Of Long, ObjectId)()
        If LayerFilter.Length = 0 Then
            Log += "kein Layerfilter angegeben!"
            Return False
        Dim Msg As String = "keine Objekte gefiltert!"
        If Obj2Move.Count = 0 Then
            _Editor.WriteMessage(Msg)
            Log += Msg
            Return True
        Msg = "Anzahl gefilterter Objekte: " & Obj2Move.Count.ToString
        Log += Msg
        Try
            Using tr As Transaction = _Database.TransactionManager.StartTransaction()
                Dim bt As BlockTable = TryCast(tr.GetObject(_Database.BlockTableId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead), BlockTable)
                Dim btrModelSpace As BlockTableRecord = TryCast(tr.GetObject(bt(BlockTableRecord.ModelSpace), Autodesk.AutoCAD.DatabaseServices.OpenMode.ForRead), BlockTableRecord)
                Dim dot As DrawOrderTable = TryCast(tr.GetObject(btrModelSpace.DrawOrderTableId, Autodesk.AutoCAD.DatabaseServices.OpenMode.ForWrite), DrawOrderTable)
                Dim objToMove As New ObjectIdCollection()
                ''For i As Integer = 0 To Obj2Move.Count - 1
                ''    objToMove.Add(Obj2Move(i))
                ''Next i
                Select Case Status
                    Case 0
                        dot.MoveToBottom(Obj2Move)
                    Case 1
                        dot.MoveToTop(Obj2Move)
                End Select
                tr.Commit()
            End Using
        Catch ex As Exception
            Log += "unerwarteter Fehler in EBL.Service > Acad > DrawOrder" & vbCrLf & ex.ToString
            Return False
        End Try
        Return True
    End Function
the problem is to select the objects.
if i call GetEntitiesOnLayer by a text-call
    <LispFunction("EBL_SEL")> _
    Public Sub EBL_SEL(ByVal rbArgs As ResultBuffer)
        GetEntitiesOnLayer("Grün")
    End Sub
it works!
if i call the draworder-function there is in line
of GetEntitiesOnLayer
psr.Status = Error {-5001}
could someone tell me why?
reagards Jan
_gile
I'm not sure to fully understand the question, but I saw some things in the code you should pay attention to.
Your GetEntitiesOnLayer() method returns an ObjectIdCollection instance. AFAIK there's no LISP equivalent to this type.
Your LispFunction should return a ResultBuffer which will be converted into a LISP list.
Another thing, the DrawOrderTable is related to a specific BlockTableRecord (ModelSpace in your code) so, your SelectionFilter should also filter the space.
        public ObjectIdCollection GetEntititesOnLayer(string layerPattern)
            var ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
            var psr = ed.SelectAll(new SelectionFilter(
                new[] { new TypedValue(8, layerPattern), new TypedValue(410, "Model") }));
            if (psr.Status == PromptStatus.OK)
                return new ObjectIdCollection(psr.Value.GetObjectIds());
            return new ObjectIdCollection();
        [LispFunction("EBL_SEL")]
        public ResultBuffer EBL_SEL(ResultBuffer resbuf)
            var ids = GetEntititesOnLayer("0");
            if (ids.Count == 0)
                return null;
            var retVal = new ResultBuffer();
            foreach (ObjectId  id in ids)
                retVal.Add(new TypedValue((int)LispDataType.ObjectId, id));
            return retVal;
Gilles Chanteau
GileCAD
GitHub
jan_tappenbeck
Hi!
thanks, but EBL_SEL is only a test call to check if the selction works outside the draworder funktion.
Jan
_gile
This seems to work for me.
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
namespace DrawOrderByLayer
    public class Commands
        enum MoveDrawOrder { ToBottom, ToTop }
        [CommandMethod("LAYERTOTOP")]
        public void SetLayerToTop()
            DrawOrderByLayer(GetEntititesOnLayer(), MoveDrawOrder.ToTop);
        [CommandMethod("LAYERTOBOTTOM")]
        public void SetLayerToBottom()
            DrawOrderByLayer(GetEntititesOnLayer(), MoveDrawOrder.ToBottom);
        private ObjectIdCollection GetEntititesOnLayer()
            var ed = Application.DocumentManager.MdiActiveDocument.Editor;
            var pso = new PromptStringOptions("\nEnter the layer name: ");
            pso.AllowSpaces = true;
            var pr = ed.GetString(pso);
            if (pr.Status != PromptStatus.OK)
                return null;
            var layerName = pr.StringResult;
            if (string.IsNullOrWhiteSpace(layerName))
                return null;
                new[] { new TypedValue(8, layerName), new TypedValue(410, "Model") }));
            if (psr.Status != PromptStatus.OK)
                ed.WriteMessage($"\nNone object found on layer: {layerName}");
                return null;
        private void DrawOrderByLayer(ObjectIdCollection ids, MoveDrawOrder order)
            if (ids == null) return;
            var db = HostApplicationServices.WorkingDatabase;
            using (var tr = db.TransactionManager.StartTransaction())
                var ms = (BlockTableRecord)tr.GetObject(
                    SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                var dot = (DrawOrderTable)tr.GetObject(ms.DrawOrderTableId, OpenMode.ForWrite);
                if (order == MoveDrawOrder.ToBottom)
                    dot.MoveToBottom(ids);
                else
                    dot.MoveToTop(ids);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
