what is the use of _AcDb.Handle.IsOne
essam-salah
Message 1 of 9
essam-salah
as its a self described title i want to know a use case for _AcDb.Handle.IsOne  ?
thanks in advance
Replies (8)
Message 2 of 9
BlackBox_
https://help.autodesk.com/view/OARX/2023/ENU/?guid=OARX-ManagedRefGuide-Autodesk_AutoCAD_DatabaseSer...
There isn't much use for Handle == 1 (or Entity 0).
"How we think determines what we do, and what we do determines what we get."
Sincpac C3D ~ Autodesk Exchange Apps
Message 3 of 9
essam-salah
@BlackBox_
i already read the documentation, another question can we know if the object exists or not using Handle ?
Message 4 of 9
_gile
You can use the undocumented Database.TryGetObjectId method.
Signature:
public bool Autodesk.AutoCAD.DatabaseServices.Database.TryGetObjectId(
    Autodesk.AutoCAD.DatabaseServices.Handle objHandle,
    out Autodesk.AutoCAD.DatabaseServices.ObjectId id)
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 5 of 9
essam-salah
@_gile
thanks for the post, so how to check if the Id is exist?
Message 6 of 9
_gile
TryGetObjectId returns true, if the supplied Handle is bound to an ObjectId (and set this ObjectId to the out parameter); false, if the supplied Handle is not bound to an ObjectId (and set the out parameter to OnjectId.Null).
Gilles Chanteau
GileCAD
GitHub
Message 7 of 9
daniel_cadext
It’s probably something internal, since it’s been around forever,A handle of One seems to always point to the AcDbBlockTable
“since all databases start with the same handseed value of 1 and go up from there”
I also wonder the purpose of mLow and mHigh?  Maybe to increase the address range back in the days of 16bit computers
Sorry if I went off topic
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
Message 8 of 9
artc2
Handles are 64-bit. mLow and mHigh are to allow 64-bit handles on 32-bit computers.
Message 9 of 9
daniel_cadext
Ah, that make more sense
