What is the difference between .Net created and Interop object created layer?
Hi Guys,
I have used VB.net created a layer. then place a polyline on this layer. Then I use Teigh object export the drawing to bmp
oHost =
New TeighaX.OdaHostApp 'Create the DDX application
oBmp =
New TeighaX.OdaBmpOut 'Create the bmp-exporter'Variable stores a reference to the current drawing
oDoc = oHost.Application.Documents.Open(strDrawingPath)
'Open a drawing from the specified dwg-file
oBmp.WriteFile(oDoc.Database, strThumbBMPPath)
This throw an error.
However if I use COM Interop Object create a layer. place the same polyline on it. Then use the same code to export drawing to bmp. There is no error.
I think there must be different between .Net created layer to COM Interop created layer. Could anybody give me a hint? This drive me mad now.
here are code
VB.Net
    Public Function AutoCADCreateLayer(ByVal strLayerName As String, Optional ByVal lngLayerColour As Long = -1, _
                                       Optional ByVal blnLayerOn As Boolean = True, Optional ByVal blnLayerLocked As Boolean = False) As Boolean
        Dim db As Database = acApp.DocumentManager.MdiActiveDocument.Database
        Dim blnRt As Boolean
        Try
            Using lock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument
                Using trans As Transaction = db.TransactionManager.StartTransaction
                    Dim objLayertb As LayerTable = db.LayerTableId.GetObject(OpenMode.ForWrite)
                    Dim objNewLayer As New LayerTableRecord
                    With objNewLayer
                        .Name = strLayerName
                        .Color = Autodesk.AutoCAD.Colors.Color.FromColorIndex(Autodesk.AutoCAD.Colors.ColorMethod.ByLayer, lngLayerColour)
                        '    .IsHidden = Not blnLayerOn
                        '   .IsLocked = blnLayerLocked
                    End With
                    objLayertb.UpgradeOpen()
                    Dim objNewLayerID As ObjectId = objLayertb.Add(objNewLayer)
                    trans.AddNewlyCreatedDBObject(objNewLayer, True)
                    db.Clayer = objNewLayerID
                    trans.Commit()
                End Using
                blnRt = True
            End Using
        Catch ex As Exception
            acApp.ShowAlertDialog("Error in create layer: " & ex.Message)
            Debug.Assert(False)
            blnRt = False
        Catch ex As SystemException
            acApp.ShowAlertDialog("Erro in create layer: " & ex.Message)
            Debug.Assert(False)
            blnRt = False
        End Try
        Return blnRt
    End Function
 COM Interop
Dim objCOMDrawing As Autodesk.AutoCAD.Interop.AcadDocument = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.AcadDocument
objCOMDrawing.Layers.Add("mylayername")
Thanks very much
Hallex
If you're adding layer in the current document
me think you need to remove" using LockDocument.. " code block from there,
just a guess, sorry
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
DiningPhilosopher
Are you sure you're asking your question in the right place ?
There's plenty of implementation differences between AutoCAD and other look-a-like APIs, and I don't know if this is the best place to ask about them.
michael_robertson
What type of error is shown? If it is in one of your catch statements what does ex.message say?
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
