using System;
using System.Collections.Generic;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.PlottingServices;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
[assembly: CommandClass(typeof(Rivilis.PDFPlot))]
namespace Rivilis
public class PDFPlot
[CommandMethod("GenPdf", CommandFlags.Session)]
public void GenPdf()
string[] files = { "C:\\FieldPlot1.dwg", "C:\\FieldPlot2.dwg", "C:\\FieldPlot3.dwg" }; // Test files with PLOTDATE field
object oldBgPlot = Application.GetSystemVariable("BACKGROUNDPLOT");
Application.SetSystemVariable("BACKGROUNDPLOT", 0);
Document oldDoc = Application.DocumentManager.MdiActiveDocument;
Database oldDb = HostApplicationServices.WorkingDatabase;
try {
foreach (string file in files) {
Document doc = Application.DocumentManager.Open(file, true);
Application.DocumentManager.MdiActiveDocument = doc;
HostApplicationServices.WorkingDatabase = doc.Database;
using (DocumentLock docloc = doc.LockDocument()) {
PlotExtents("DWG To PDF.pc3", "ISO_expand_A4_(210.00_x_297.00_MM)", "monochrome.ctb", file + ".pdf");
doc.CloseAndDiscard();
Application.DocumentManager.MdiActiveDocument = oldDoc;
HostApplicationServices.WorkingDatabase = oldDb;
Application.SetSystemVariable("BACKGROUNDPLOT", oldBgPlot);
catch (System.Exception e) {
System.Windows.Forms.MessageBox.Show(
e.ToString(),
"Error",
System.Windows.Forms.MessageBoxButtons.OK,
System.Windows.Forms.MessageBoxIcon.Error);
// Plotting progress based on
// http://through-the-interface.typepad.com/through_the_interface/2007/09/driving-a-multi.html
static public void PlotExtents(string printer, string format, string styleSheet, string pdfFilePath)
Document doc = Application.DocumentManager.MdiActiveDocument;
Editor ed = doc.Editor;
Database db = doc.Database;
try {
using (Transaction tr = db.TransactionManager.StartTransaction()) {
BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead);
Layout lo = (Layout)tr.GetObject(btr.LayoutId, OpenMode.ForRead);
PlotInfo pi = new PlotInfo();
pi.Layout = btr.LayoutId;
PlotSettings ps = new PlotSettings(lo.ModelType);
PlotConfigInfo pci = new PlotConfigInfo();
ps.CopyFrom(lo);
ps.PlotPlotStyles = true;
PlotSettingsValidator psv = PlotSettingsValidator.Current;
psv.SetStdScaleType(ps, StdScaleType.ScaleToFit);
psv.SetDefaultPlotConfig(ps);
psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
psv.SetUseStandardScale(ps, true);
psv.SetPlotCentered(ps, true);
////PS-PlotRotation
Extents2d extent2d = ps.PlotPaperMargins;
if (extent2d.MaxPoint.Y > extent2d.MaxPoint.X) {
psv.SetPlotRotation(ps, PlotRotation.Degrees000);
else {
psv.SetPlotRotation(ps, PlotRotation.Degrees090);
try {
psv.SetPlotConfigurationName(ps, printer, null);
psv.SetPlotConfigurationName(ps, printer, format);
psv.SetPlotPaperUnits(ps, PlotPaperUnit.Millimeters);
e.GetBaseException().ToString();
psv.GetCanonicalMediaNameList(ps);
pi.OverrideSettings = ps;
PlotInfoValidator piv = new PlotInfoValidator();
piv.MediaMatchingPolicy = MatchingPolicy.MatchEnabled;
piv.Validate(pi);
if (PlotFactory.ProcessPlotState == ProcessPlotState.NotPlotting) {
using (PlotEngine pe = PlotFactory.CreatePublishEngine()) {
PlotProgressDialog ppd = new PlotProgressDialog(false, 1, true);
using (ppd) {
ppd.set_PlotMsgString(PlotMessageIndex.DialogTitle, "Plot Progress");
ppd.set_PlotMsgString(PlotMessageIndex.CancelJobButtonMessage, "Cancel Job");
ppd.set_PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage, "Cancel Sheet");
ppd.set_PlotMsgString(PlotMessageIndex.SheetSetProgressCaption, "Sheet Set Progress");
ppd.set_PlotMsgString(PlotMessageIndex.SheetProgressCaption, "Sheet Progress");
ppd.LowerPlotProgressRange = 0;
ppd.UpperPlotProgressRange = 100;
ppd.PlotProgressPos = 0;
ppd.OnBeginPlot();
ppd.IsVisible = true;
ppd.OnBeginPlot();
pe.BeginPlot(ppd, null);
pe.BeginDocument(pi, doc.Name, null, 1, true, pdfFilePath);
ppd.OnBeginSheet();
ppd.LowerSheetProgressRange = 0;
ppd.UpperSheetProgressRange = 100;
ppd.SheetProgressPos = 0;
PlotPageInfo ppi = new PlotPageInfo();
pe.BeginPage(ppi, pi, true, null);
pe.BeginGenerateGraphics(null);
ppd.SheetProgressPos = 50;
pe.EndGenerateGraphics(null);
pe.EndPage(null);
ppd.SheetProgressPos = 100;
ppd.OnEndSheet();
pe.EndDocument(null);
ppd.PlotProgressPos = 100;
ppd.OnEndPlot();
pe.EndPlot(null);
else {
ed.WriteMessage("\nCannot plot. System is busy plotting another one.");
tr.Commit();
// Display the error message here.
e.ToString(),
"Error",
This code was tested with AutoCAD 2012 and seems to work as expected.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
