vbcrlf equivalent in c#
Searching for hours in the help for c# couldn't find anything under carriage
return or line feed
Finally used reflector to look at a vb code snippet and found
ChrW(13) + ChrW(10)
as in
ed.WriteMessage(btr.Name + ChrW(13) + ChrW(10))
however when i put that in code error says ChrW doesn't exist in this
namespace
so search in help for ChrW under c# and find the method which says it's
under Strings.ChrW
but when I added strings. i get error that Strings isn't in namespace
in the help page Filtered by C# entering chrw in index pulls up a page
saying it's visualbasic
and the strings class is under microsoft.visualbasic namespace...but i'm
trying to do it in c# so i'm a bit confused
finally at the end of that method description it shows function defs for
diff langs
i had to enter a function def
public static char ChrW(
int CharCode
)in order to use chrw but i dont' think that should be required????also i
had to change & to + to concatenate the chrw returnwhat am i missing?thanks
mark
how about "\r\n" ?
or
ed.WriteMessage("\n{0}", btr.Name); Edited by: danielm103 on Sep 10, 2009 9:49 PM
perhaps try ...
Environment.NewLine
/// kdub
"mp" wrote in message
news:6252744@discussion.autodesk.com...
return or line feed
ChrW(13) + ChrW(10)
as in
namespace
under Strings.ChrW
diff langs
int CharCode
mark
venturing into c#? there is tons of stuff on the net.
http://dotnetperls.com/whitespace
return or line feed
ChrW(13) + ChrW(10)
as in
namespace
under Strings.ChrW
diff langs
int CharCode
mark
Thanks to all, kerry, daniel and fieldguy!
"fieldguy" wrote in message
news:6253024@discussion.autodesk.com...
return or line feed
