AECOBJEXPLODE
AECOBJEXPLODE
arcticad
Advisor Advisor
AECOBJEXPLODE
arcticad
Is there a .NET version of AECOBJEXPLODE?
Thank You
(defun botsbuildbots() (botsbuildbots))
Not sure if they've added a utility in the newer versions, '09 or '10, but
in prior version you had to bind all xref's, loop through all entities in
all block table records, explode Geo objects, add the results back to the
owner, and delete the Geo. If you don't have a problem loading the document
in the editor, then it may be best to run the AECOBJEXPLODE command.
Bobby C. Jones
http://bobbycjones.spaces.live.com
wrote in message news:6253142@discussion.autodesk.com...
Thank You
arcticad
Thanks Bobby, I'll try it out
