- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
In Inventor I was able to pass a custom paper size to the "DrawingPrintManager" (See top screenshot below). I am trying to setup the same print command in AutoCAD, but clearly the format is different. I admit I am new to programming in AutoCAD. I get the feeling that the custom sheet size is set in the plotter driver, which is outside the realm of the AutoCAD API. However I ran Kean Walmsley's mplot which spits out a list of the media sheets/device. It shows that a "Custom Size" exists for this device. I'm not sure if that's a glimmer of hope or if I should be put out of my misery.
