Insert Bitmap File as OLE Object as an Embedded with C# on AutoCAD 2022
EtapAutodesk
EtapAutodesk
We want to import bitmap file as embedded on Autocad DWG drawing with programmatically [C#]. Is it possible?  I do not find any source .NET code resolution for this. There seems a OLE2FRAME class but i do not see any resolution.
Thanks!
norman.yuan
No, there is no API exposed to do that. Here is an old reply to the same question posed years ago, and it still stand, I think.
https://forums.autodesk.com/t5/net/how-to-create-an-ole-object-with-ole2frame/td-p/3203222
Norman Yuan
Drive CAD With Code
