Using sample projects from ObjectARX
I want to use C# sample projects from ObjectARX 2013 to make dlls. How can I select them using Visual Studio 2010. When I try, the error message says give absolute path. Even if I give it, no response.
Shall be thankful for help.
AloyH
Alfred.NESWADBA
Can you create a screenshot when you see the message? At least I don't know what you are speaking about and when does the error raise up (while loading a C#-project, while compiling it, while setting the references in the project, while loading it into AutoCAD, ...)
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Thanks Alfred,
I was able to add the two C# files in the EllipseJig folder as existing items, build the dll, NETLOAD in AutoCAD and run. They were in dotNet section of ObjectARX 2013..
AloyH
Alfred.NESWADBA
I hope you haven't just copied them into the folder, you also have added them to the C#-project 😉 A file in the directory is not automatically used in the project.
- alfred -
Alfred NESWADBA
Hi Alfred,
No, I did not copy. I simply sected them from the folder. Deleted the classLibrary C# file tha twas created automatically and built the dll.  Why cannot I do the same on other types like com in ObjectARX 2013 sample projects. I now see how Civil 3D created.
AloyH
