changes in DocumentCollectionEventArgs in 2013
this code used to work in AutoCAD 2007-2012, but not in 2013
    xAcad = Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication
    ThisDrawing = xAcad.ActiveDocument
    Public Sub AddDocumentToBeDestroyedEvent()
        Try
            AddHandler Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.DocumentToBeDestroyed, AddressOf subDocumentToBeDestroyed
        Catch
        End Try
    End Sub
    Public Sub subDocumentToBeDestroyed(ByVal senderObj As Object, ByVal docColDocActEvtArgs As DocumentCollectionEventArgs)
        Try
            If ThisDrawing Is docColDocActEvtArgs.Document.AcadDocument Then
            Else
        Catch ex As System.Exception
            MsgBox("Error en docColDocAct: " & ex.Message)
        End Try
    End Sub
it sends the error 'AcadDocument' is not a member of 'Autodesk.AutoCAD.ApplicationServices.Document'
anybody knows the new way to check in both documents are equal?
Alfred.NESWADBA
Use this code for 2013 the get the COM-object of the AutoCAD-document (im my snippet: AcadDoc)
Imports Autodesk.AutoCAD
CType(ApplicationServices.DocumentExtension.GetAcadDocument(AcadDoc), Interop.AcadDocument)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
yep, this work
            If ThisDrawing Is CType(Autodesk.AutoCAD.ApplicationServices.DocumentExtension.GetAcadDocument(docColDocActEvtArgs.Document), Autodesk.AutoCAD.Interop.AcadDocument) Then
thanks a lot
regards
