Unlock layer of selected object
I have a drawing file which contains several layers and some of which are locked. When I select objects and want to display block name, I can do that easily for objects in unlocked layers but when I come across objects in Locked layer code throws an error "eOnLockedLayer" and exits.
My question is, how can I find the layer associated with the selected object and unlock it if it is locked > Display Blockname > lock that particular layer again.
Thank you,
ActivistInvestor
Thank you,
You can use the optional 4th argument to the Transaction.GetObject() method to open objects on locked layers for write:
  myTransaction.GetObject(someObjectId, OpenMode.ForWrite, false, true);
When OpenMode is OpenMode.ForWrite, and the forth argument is true, you will not get an eOnLockedLayer exception, and there's no need to unlock any layers.
