Transfer an array from MyCommands class to a Windows Form
muckmailer
muckmailer
What is the best way to Transfer an array from MyCommands class to a Windows Form? Example Windows Form 1.
Should the array be made public static or is there a better way. that is simple for a beginner.
If there is an example that would be helpful.
Thank you
_gile
To get a pertinent reply you have to provide more informations about this "form".
Is it a modal dialog related to some CommandMethod, typically a dialog box used to get user inputs requiered by this command?
Or is it a modeless dialog, typically a Palette displayed independently?
You should also say more about the "array". What does it contain? How is it filled? And so on.
Gilles Chanteau
GileCAD
GitHub
