TRYING TO REPLACE DAINAMIC BLOCK IN PLACE OF OBJECTS
nesara_r
Message 1 of 13
nesara_r
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
namespace Block_Replace
    public class Replace_objects
        [CommandMethod("ReplaceObjects")]
        public void ReplaceObjects()
            Document doc = Application.DocumentManager.MdiActiveDocument;
            Database db = doc.Database;
            Editor editor = doc.Editor;
            PromptSelectionResult selectionResult = editor.GetSelection();
            if (selectionResult.Status != PromptStatus.OK)
                editor.WriteMessage("No objects selected.");
                return;
            SelectionSet selectionSet = selectionResult.Value;
            using (Transaction trans = db.TransactionManager.StartTransaction())
                // Prompt user to select dynamic block reference
                PromptEntityOptions promptOptions = new PromptEntityOptions("\nSelect dynamic block reference: ");
                promptOptions.SetRejectMessage("Invalid selection. Please select a dynamic block reference.");
                promptOptions.AddAllowedClass(typeof(BlockReference), true);
                PromptEntityResult promptResult = editor.GetEntity(promptOptions);
                if (promptResult.Status != PromptStatus.OK)
                    editor.WriteMessage("No dynamic block reference selected.");
                    return;
                BlockReference dynamicBlockReference = trans.GetObject(promptResult.ObjectId, OpenMode.ForRead) as BlockReference;
                foreach (ObjectId objectId in selectionSet.GetObjectIds())
                    Entity selectedEntity = trans.GetObject(objectId, OpenMode.ForRead) as Entity;
                    if (selectedEntity == null)
                        continue;
                    // Create a new block reference at the same position
                    BlockReference newBlockRef = dynamicBlockReference.Clone() as BlockReference;
                    newBlockRef.Position = selectedEntity.GeometricExtents.MinPoint;
                    // Add the new block reference to the model space
                    BlockTableRecord ms = trans.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForWrite) as BlockTableRecord;
                    ms.AppendEntity(newBlockRef);
                    trans.AddNewlyCreatedDBObject(newBlockRef, true);
                trans.Commit();
ABOVE BLOCK NEED TO BE REPLACED BY OTHER BLOCK
THE BLOCK GOT PASTE BUT IT IS LOOSING ITS DYNMIC  PROPERTIES I WANT TO RETAIN THOSE DAINAMIC PROPERTIES AFTER REPLACING ALSO.
I TRIED TO REPLACE THOSE BLOCKS BY THE ABOVE BLOCK
Accepted solutions (4)
Replies (12)
Message 2 of 13
ActivistInvestor
You cannot use Clone() to do this. You have to use the DeepCloneObjectsl() method. Alternately, you can use the ActiveX Copy() method.
Message 3 of 13
norman.yuan
It seems to me that you might not fully understand how dynamic block works, or you would not call Clone() to create a dynamic BlockReference instance, which is most likely an anonymous block. While you can use DeepCloneObjects() for your purpose, it would not help you to know how dynamic block reference is created and how the dynamic properties are set.
In your case, after user picks a dynamic blockreference to "copy", your code should do these:
1. Retrieve the dynamic blockreference's dynamic properties into collection, such as Dictionary<string, object>;
2. When looping through the selection set (in order to decide the insertion point of "copied" block reference), you create a NEW BlockReference instance of the dynamic block, then you set its dynamic properties use the retrieved property name/value pair in the Dictionary. When the dynamic properties are set, AutoCAD would automatically change the newly inserted BlockReference's block definition to an anonymous block definition, if necessary.
The code would look like (not tested):
                return;
                    return;
                // Retrieve dynamic properties from the block reference
                Dictionary<string, object> props=GetDynamicProperties(dynamicBlockReference)
                ObjectId blockDefinitionId=dynamicBlockReference.DynamicBlockTableRecord;
                        continue;
                    ////BlockReference newBlockRef = dynamicBlockReference.Clone() as BlockReference;
                    ////newBlockRef.Position = selectedEntity.GeometricExtents.MinPoint;
                    // Create new dynamic block reference
                    var newBlockRef = new BlockReference(selectedEntity.GeometricExtents.MinPoint, blockDefinitionId)
                    // if the block definition has attributes defined,
                    // you would want to add AttributeReferences accordingly here
                    // set dynamic properties of the new block reference
                    foreach (DynamicBlockReferenceProperty prop in newBlockRef.DynamicBlockReferencePropertyCollection)
                       var propName=prop.PropertyName;
                       var propValue=props[propName];
                       prop.Value = propValue;
                trans.Commit();
        private Dictionary<string, object> GetDynamicProperties(BlockReference blkRef)
            var dict= new Dictionary<string, object>();
            foreach (DynamicBlockReferenceProperty prop in blkRef.DynamicBlockReferencePropertyCollection)
                dict.Add(prop.PropertyName, prop.Value);
            return dict;
Norman Yuan
Drive CAD With Code
Message 4 of 13
ActivistInvestor
Message 5 of 13
ActivistInvestor
If you want to create copies of objects, whether they are Dynamic block references or anything else, then you use the API methods that are provided to copy them, which are the ones I mentioned previously.
That is what they are there for, there is no need for you to reinvent those methods.
If you use those APIs, then you do not have to also deal with all of the other potential issues related to copying Dynamic blocks, such as attributes; fields in attributes; and so forth.
See this post for an example use of  DeepCloneObjects.
Message 6 of 13
nesara_r
thankyou for advice after going through your solution i used it in my project now it is  working
Message 7 of 13
ActivistInvestor
Great. The example I pointed to was courtesy of @_gile, for the record.
Message 8 of 13
nesara_r
can i give select similar option to the user while selecting the objects in the same code above
Message 9 of 13
ActivistInvestor
Yes you could do that, but it involves some work, and to provide the full functionality of the SELECTSIMILAR command would be non-trivial (actually, I always felt that select similar functionality should have been better-integrated, and be available at any select objects prompt, but that's another story...).
You could also just instruct the user to do it in-advance by right-clicking (or using the SELECTSIMILAR command),  and then starting your command and specifying the Previous selection set in response to the Select Objects: prompt.
Message 10 of 13
nesara_r
i tried using select similar in first place and then run my command but when i run my command the objects selected previously is getting deselected.
Message 11 of 13
ActivistInvestor
You have to use the CommandFlags.UsePickSet flag in your CommandMethod:
[CommandMethod("ReplaceObjects", CommandFlags.UsePickSet)]
Message 12 of 13
nesara_r
    // Get the newly created block reference
    var newBlockRefId = mapping[dynamicBlockId].Value;
    var newBlockRef = (BlockReference)trans.GetObject(newBlockRefId, OpenMode.ForWrite);
    // Set the position of the new block reference to the position of the selected entity
Message 13 of 13
nesara_r
i want to get coordinates of OBJECT I select and need to paste the new block reference there
