Transfer Link Template to Object Data
BriamR
Message 1 of 18
BriamR
Hi community,
I have been researching on this topic for a long time, what I want is to transfer the values of the LINK TEMPLATE fields to the OBJECT DATA fields as I show in the image is a process that would help me a lot.
I have a .dwg file with two OBJECT DATA tables which are connected to a MS Access database by means of a LINK TEMPLATE with the same names as shown in the SCREENCASTS.
I have looked at these options but without achieving something concrete
1. ADOLisp
2. MS-Access-and-Object-datos
3. ms-acceso-a-atributos
I attach the .mdb and .dwg files that serve as an example for this topic.
Can you help me with a routine that does this task automatically and faster?
I appreciate your help if you have it.
Replies (17)
Message 2 of 18
hosneyalaa
Hi @BriamR
I not used it before and I don't know how to use it, you have a video look
But I looked at it a little
 But you have one KeyValues Can two KeyValues I mean the first and second fields KeyValues
Message 3 of 18
BriamR
Hi @hosneyalaa
The keyvalues is only one in the DB and in the LT, for each table the keyvalues is INTERNO_DEMARCACION and INTERNO_SENAL. thanks for your interest in the publication
Message 4 of 18
hosneyalaa
hi @BriamR
Get the following values after the key need arrangement See the video
and connect it with OBJECT DATA fields needs time
If I find time, I will try it
Can someone provide help?
Attach the Lisp
Message 5 of 18
BriamR
@hosneyalaathanks for the help and interest in solving the issue, greetings, I hope someone in the forum can help me with the issue.
I have been reviewing this method and I think I can use it but I still can't make an effective or coherent routine to help me with transferring LT to OD. CAO_Link_Templates.lsp
Message 6 of 18
Gepaha
I assume you want to develop this with AutoCAD .NET API.
I have never used AutoCAD MAP Object Data but I have used AutoCAD CAO.
Why don't you start writing some code and see what happens?
I can help with issues related to CAO but nothing related to Object Data.
At first I think that it is only possible to migrate data from CAO to Object Data as long as the CAO.KeyValues ​​fields are equal to the ObjectData.FieldDefinition fields (same data source).
The caotest.dvb (VBA) example can be used for learning purposes. Other useful content:
https://www.autodesk.com/autodesk-university/class/Harnessing-Power-AutoCAD-COM-APIs-2015
Message 7 of 18
BriamR
@Gepaha Thank you for your interest in the publication. I will try to make some lines as you recommend, because I don't have much experience in programming. I am still open to your help in terms of a code that can migrate or transfer the information from LT to OD. Regards
Message 8 of 18
Norman_Yuan
You did not give details on how you want to transfer/conversion done: is it one-time operation, so that the entities' linked data will be converted into ObjectData attached to the same entities and afterward, you do not need the entities being linked to the data any more; or, you want to entities still to be data linked (thus the attached ObjectData may be out of sync, if the data changes).
There is also other possibilities. For example, if you know which data fields in the database's table to be used as ObjectData, then you can directly get the database from the database and use it in the ObjectData fields (e.g. bypassing the need to converting/transferring from data linked entities, unless you must use the linked data to identify the entities).
As @Gepaha pointed out, you would need use CAO 1.0 COM components to access data linked entities, and then create corresponding ObjectData (table/record). It can be done either with VBA, or .NET API. I suspect that is no existing, generic tool readily for you to use (because CAO is quite old technology), so, you need to have, a bit of, advanced AutoCAD/Map programming knowledge/skill for this task. If you want to it yourself, expect steeper learning curve, and preferably, you do it with .NET API, rather than VBA.
Norman Yuan
Drive CAD With Code
Message 9 of 18
BriamR
@Norman_Yuan thank you very much for your interest in the subject.
Regarding the information that I did not provide, I would like to comment the following details,
1. When the operation of transferring the LT to the OD is done, it must be a copy of information that keeps the entity or drawing linked to the database regardless of the fact that this is not synchronized by subsequent changes in value.
2. The values of the OD and LT and DB fields are the same, that is to say, the copy or conversion/transfer from LT or DB to OD can be made, and yes, the data linked through the LT are identifiers of each entity or graphic element with OD.
Thanks again for commenting on this publication, I remain attentive to any clarification to be made on this issue. And yes! I am dabbling in this programming as it is very useful and interesting to save time in work processes, so I turn to this forum asking for your help. Regards
Message 10 of 18
hosneyalaa
Hi @BriamR
You need to look at lisp at comment  show link data
 It gives you the results you want From the LT fields
Then you associate it with the OD fields Through the Lisp that you attached
Message 11 of 18
BriamR
Hi @hosneyalaa, Try to run these lisp with support from caotets.lsp
(defun c:LT2OD( LTs linkTemplate linkSel objId
			      / link txtLinkData selectedObj selectedObjID linkKeyValues
			      linkindex KeyType KeyValue strKeyValue lstLinkData linkTypes strLinkTypes ss)
  ;; Load the ActiveX stuff for Visual LISP
  (vl-load-com)
  ;; Save a reference to the active drawing document.
  (setq acadObj (vlax-get-acad-object)
	acadDoc (vla-get-ActiveDocument acadObj)  ) ; This acadDoc global is used throughout this file.
  (setq gCmnFiles (getenv "COMMONPROGRAMFILES")
	gCaoTlb (strcat gCmnFiles "\\AUTODESK SHARED\\" "cao20enu.tlb")
	gADO-DLLpath (strcat gCmnFiles "\\system\\ado\\msado15.dll"))
  (if (null (findfile gADO-DLLpath))
      (progn
	(alert (strcat "Could not load ADO type library from: " gADO-DLLpath))
	(exit)
  ;; Import the ADO type library
  ;; Note: We must provide prefixes for these methods and properties because some conflict
  ;; with protected LISP symbols such as APPEND().
  (if (null adok-adStateOpen)            ; Check that ADO type library has not yet been loaded.
      (vlax-import-type-library :tlb-filename gADO-DLLpath)
  ;; Import the CAO type library.
  (if (null GetLinkTemplates)
      (vlax-import-type-library :tlb-filename gCaoTlb)
  ;; Define a global variable, dbConnect
  ;;(InitDbConnect)
  (setq dbConnect (vla-getinterfaceobject (vlax-get-acad-object) "CAO.DbConnect.20"))
  (setq LTs (vlax-invoke-method dbConnect "GetLinkTemplates")) ; All linkTemplates in current drawing.
    (setq linkKeyValues (vlax-get-property link "KeyValues"))
    (if (null linkKeyValues)
	(setq lstOutput  (append lstOutput (list "No key value is defined")))
	(vlax-for OneKeyValue linkKeyValues
		  (setq KeyValue (vlax-variant-value (vlax-get-property OneKeyValue "Value"))
			KeyType (type KeyValue))
		  (cond
		   ((equal vlax-vbString KeyType)
		    (setq strKeyValue (strcat "'" KeyValue  "'" ))
		   ((or
		     (equal vlax-vbInteger KeyType)
		     (equal vlax-vbLong KeyType)
		     (equal vlax-vbSingle KeyType)
		     (equal vlax-vbDouble KeyType)
		     (equal 'INT KeyType)
		     (equal 'REAL KeyType)
		    (setq strKeyValue (vl-princ-to-string KeyValue))
		   ((equal vlax-vbBoolean KeyType)
		    (if (equal :vlax-true KeyValue)
			(setq strKeyValue "True")
		      (setq strKeyValue "False"))
		   ((equal 'STR KeyType)
		   (t
		    (setq strKeyValue  "Unknown type")
		  );_cond
		  (setq lstLinkData (append lstLinkData
					    (list (strcat (vlax-get-property OneKeyValue "FieldName") ": " strKeyValue))))
        );_vlax-for OneKeyValue linkKeyValues
      );_if not null keyValues
(defun c:LTOD( / LTs linkTemplate linkSel keyValues keyDescriptions keyDescsCount index)
  (vl-load-com)
      (progn
	(exit)
  (vlax-for thisLT LTs
	    ;; Dump the Link Template
	    (princ (vlax-dump-object thisLT))
	    ;; Get all links in this drawing which use this link template
	    (setq linkSel (vlax-invoke-method DbConnect "Getlinks" thisLT ))
	    (vlax-for thisLink linkSel
		      (princ (vlax-dump-object thisLink))
		      (setq KeyValues (vlax-get-property thisLink "KeyValues"))
		      (vlax-for thisKey KeyValues
				(princ (vlax-dump-object thisKey))
Even without achieving much, I get the error I show, any help you can give me to run these lisp where I can transfer the Link Template to the Object Data, thank you, greetings.
Message 12 of 18
hosneyalaa
HI
You can complete with this code
Code adapted from caotets.lsp
(defun c:TESSTDLink (/ ACADDOC ACADOBJ ADOCONNECT CMD COUNT DBCONNECT ENT1 GADO-DLLPATH GCAOTLB GCMNFILES
		LA_OBJ_IDS LINKTEMPLATE LINKTEMPLATENAME LIST_FIELD_TARGET LSTALLROWS LTGETGETLABELTEMPLATES
		LTGETQUERIES LTS L_FIELD L_OBJ_ID OBJ OB_ID PKEYDESCS PKEYVALUES RS SELECTEDROWINDEX STRCOLUMNNAMES
		STRKEYNAME TBL THISKEYVALUE THISVALUE THISVALUE0 THISVALUE1 TYP_TARGET TYP_TARGET0 XS0 XS0Q)
(vl-load-com)
  (vl-load-com)
  ;; (setq linkTemplates (vl-catch-all-apply 'caom-GetLinkTemplates (list dbConnect acadDoc)))
      (progn
	(exit)
     	  :methods-prefix "adom-"
 	  :properties-prefix "adop-"
 	  :constants-prefix "adok-"
  (if (null caom-GetLinkTemplates)           ; Check that CAO type library has not yet been loaded.
     	  :methods-prefix "caom-"
 	  :properties-prefix "caop-"
 	  :constants-prefix "caok-"
;;; Get the object and get the object ID
(setq ent1 (car (entsel "\nSelect entity to erase links")))
(setq Obj (vlax-ename->vla-object ent1))
(setq ob_ID (vla-get-objectid Obj))
;;; Instantiate the DBConnect object
(setq dbConnect (vlax-create-object "CAO.DbConnect.20"))
;prepare the keydescriptions
(setq pKeyDescs (vla-GetInterfaceObject (vlax-get-acad-object)"CAO.KeyDescriptions.20"))
(setq pKeyValues (vla-GetInterfaceObject (vlax-get-acad-object)"CAO.KeyValues.20"))
;;; Get the GetLabelTemplates
(setq LTGetGetLabelTemplates (vlax-invoke-method dbConnect "GetLabelTemplates"))
;;; Get the linkTemplates     (setq lA_Obj_IDS NUL)
  (vlax-for  LT LTs
    (vlax-for thisLink (vlax-invoke-method dbConnect "GetLinks" LT nil nil nil)
      (setq l_Obj_ID (vlax-get-property thisLink "ObjectID"))
      (if (= l_Obj_ID ob_ID)
	(setq lA_Obj_IDS (CONS thisLink lA_Obj_IDS))
(setq linkTemplate (CAR lA_Obj_IDS))
  (setq linkTemplatename (vlax-get-property (vlax-get-property linkTemplate "linkTemplate") "Name") )
   (setq thisKeyValue (vlax-invoke-method (vlax-get-property linkTemplate "KeyValues") "Item" 0) )
  (setq strKeyName (vlax-get-property thisKeyValue "FieldName"))
  (setq thisValue (vlax-variant-value (vlax-get-property thisKeyValue "Value")))
 (setq adoconnect nil)
  (setq ADOConnect (vlax-create-object "ADODB.Connection") )
   (cmdConnectDataSource_Click linkTemplate)
 (setq Count  0
	cmd (vlax-create-object "ADODB.Command"))
  (vlax-put-property cmd "ActiveConnection" ADOConnect)
  (vlax-put-property cmd "CommandTimeout"  30)
  (vlax-put-property cmd "CommandText" (strcat"SELECT * from "
					      (vlax-get-property (vlax-get-property linkTemplate "linkTemplate") "Table")))
  (setq rs nil)
  (setq rs (vlax-create-object "ADODB.Recordset"))
  (vlax-invoke-method rs "OPEN" cmd nil adok-adOpenDynamic adok-adLockBatchOptimistic adok-adCmdUnknown)
  (princ (strcat "\n " (itoa (vlax-get-property rs "recordCount")) " Rows"))
  (princ (printFieldNames rs nil))
  (princ  "\n")
  (princ  "\n")
  (princ  "\n")
;;;  (setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
;;;  (vla-regen acDoc acAllViewports)
;;; Connect to the datasource and table for this linkTemplate.         ;
;;; Display the ADODB Connection object's Version and Provider info.   ;
(defun cmdConnectDataSource_Click( linkTemplate	; Pass in linkTemplate argument, or nil
				   /  strDataSourceLoc strDataSource
				     currConnectionString )
;;;  (if (null linkTemplate) (setq linkTemplate (getLinkTemplate)) )
  (setq strDataSourceLoc (strcat (vlax-get-property dbConnect "DataSourceLocation") "\\")
	strDataSource (vlax-get-property (vlax-get-property linkTemplate "linkTemplate") "DataSource") )
  (if adoConnect
      (if (= adok-adStateOpen (vlax-get-property ADOConnect "State"))
	  (vlax-invoke-method ADOConnect "Close")))
  (setq ADOConnect (vlax-create-object "ADODB.Connection") ) ; ADOConnect is a global
  (setq currConnectionString (strcat "File Name=" strDataSourceLoc strDataSource
				     ".udl;User ID=;Password=;" ))
  (vlax-put-property ADOConnect "ConnectionString" currConnectionString)
  (vlax-invoke-method ADOConnect "Open" currConnectionString "" "" -1) ; LISP seems to require args which should be optional...
;;;  (if (= adok-adStateOpen (vlax-get-property ADOConnect "State"))
;;;      (alert (strcat strDataSource " is connected."
;;;		     "\nVersion = " (vlax-get-property ADOCOnnect "Version")
;;;		     " Provider = " (vlax-get-property ADOCOnnect "Provider")))
;;;    (alert (strcat "Unable to connect to " strDataSource))
  (setq status_string (strcat "ADODB.Connection.OPEN( "
;;; printFieldNames() accepts an ADODB.RecordSet object and returns a  ;
;;; string containing the column names for this RecordSet's Fields.    ;
(defun printFieldNames( rs bPrint / strColumnNames fields fieldsIndex thisField padStr
			   fieldsCount thisFieldDefinedSize thisFieldName )
  (setq strColumnNames ""
	padStr         "")
  (setq fields (vlax-get-property rs "Fields")
	fieldsCount (1- (vlax-get-property fields "Count")) ; zero-based index
	fieldsIndex 0)
  (while (<= fieldsIndex fieldsCount)
    (setq thisField (vlax-get-property fields "item" fieldsIndex)) ; Item is a property not a method for recordSet fields...
    (setq thisFieldDefinedSize (vlax-get-property thisField "DefinedSize")
	  thisFieldName (vlax-get-property thisField "Name"))
    (if (< fieldsIndex fieldsCount) ; Don't output final comma after last fieldname
	(setq strColumnNames (strcat strColumnNames thisFieldName ", "))
      (setq strColumnNames (strcat strColumnNames thisFieldName))
    (setq fieldsIndex (1+ fieldsIndex))
  ;; Print these field-names
    (if bPrint
	(princ (strcat "\n" strColumnNames "\n")))
  strColumnNames	; Return this value
To show the values in the lines use this code
;;; Utility function which accepts an ADODB.RecordSet object and a boolean.
;;; Each record in the recordSet is converted to a list of strings.    ;
;;; This routine returns a list of these list-of-string records.       ;
;;; Set 2nd arg, bPrint == T to print records to screen, otherwise nil ;
;;; to just return the recordset fields as a list-of-list-of-string.   ;
(defun printFieldValues( rs bPrint / fields fieldsIndex thisField rowIndex lstAllRows
			    fieldsCount strFieldValue strOneRow thisValue )
  (while (not (equal :vlax-true (vlax-get-property rs "EOF")))
	  fieldsIndex 0
	  strOneRow nil)
    ;; Print out record count:
    ;;  (princ (setq (strcat "\nThere are " (vl-princ-to-string fieldsCount)  " fields:\n\n")))
      (setq thisValue (vlax-variant-value (vlax-get-property thisField "Value")))
      (setq strFieldValue (vl-princ-to-string thisValue))
      (setq strOneRow (append strOneRow (list strFieldValue)))
      (if (< fieldsIndex fieldsCount ) ; Don't output final comma after last fieldname
	  (setq strOneRow (append strOneRow (list ", ")))
     );_while fieldsIndex
    (setq lstAllRows (cons (apply 'strcat strOneRow) lstAllRows))
    ;; Display these field-names
    (if bPrint
	(progn
	  (princ (apply 'strcat strOneRow))
	  (princ "\n")
    (vlax-invoke-method rs "MoveNext") ; Move to next row in recordSet.
    );_while not yet at RecordSet EOF
  (setq lstAllRows (reverse lstAllRows)) ; Return this big list of all rows.
Message 13 of 18
BriamR
(defun c:LT_OD (/ dwg ss sdm-dem-demarcacion sdm-dem-inter-demarcacion sdm-dem-clase-demarcacion link-template link-template-field db-file db-table db-field db-clase-field conn rs int-dem clase-dem)
  (setq dwg (vlax-get-acad-object))
  (setq ss (ssget))
  (setq sdm-dem-demarcacion "SDM_DEM_DEMARCACION")
  (setq sdm-dem-inter-demarcacion "INTERNO_DEMARCACION")
  (setq sdm-dem-clase-demarcacion "CLASE_DEMARCACION")
  (setq link-template "SDM_DEM_DEMARCACION")
  (setq link-template-field "INTERNO_DEMARCACION")
  (setq db-file (strcat (getvar 'dwgprefix) "SIGMOVILIDAD_2012.mdb"))
  (setq db-table "DEM_DEMARCACION")
  (setq db-field "INTERNO_DEMARCACION")
  (setq db-clase-field "CLASE_DEMARCACION")
  (setq conn (vl-catch-all-apply 'vla-get-activedocument (list dwg)))
  (setq rs (vl-catch-all-apply 'vlax-create-object (list "ADODB.Recordset")))
  (foreach obj (vl-remove-if-not 'vla-object->ename (mapcar 'vlax-ename->vla-object (ssnamex ss)))
    (if obj
      (progn
        (setq int-dem (vla-putproperty obj link-template link-template-field))
        (vl-catch-all-apply 'vlax-invoke-method rs "Open" (list (strcat "SELECT * FROM " db-table " WHERE " db-field "=" int-dem) conn))
        (if (not (vlax-invoke-method rs "EOF"))
          (progn
            (setq clase-dem (vlax-invoke-method (vlax-get-property rs "Fields") db-clase-field "Value"))
            (vla-putproperty obj sdm-dem-demarcacion sdm-dem-inter-demarcacion int-dem)
            (vla-putcustomstringdata obj sdm-dem-demarcacion sdm-dem-clase-demarcacion clase-dem)
        (vlax-invoke-method rs "Close")
  (princ)
  (princ "Valores de campos copiados con éxito a Object Data.")
  (princ)
  (prin1)
I have been working with this code to solve the issue of copying the LT in the OD; it generates the following ; error: bad argument type: lentityp (0 <Entity name: 1f248ae1f30> 3)
I am still trying to get the expected result, any ideas?
Message 14 of 18
hosneyalaa
change
with
(mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss)))
; error:
          no function definition: VLA-PUTPROPERTY
Message 15 of 18
BriamR
I added this at the beginning of the code, but the error persists...
  (vl-load-com)
  (setq acad (vlax-get-acad-object))
  (setq doc (vla-get-activedocument acad))
  (setq modelspace (vla-get-modelspace doc))
Command: LTOD
1 found
; error: no function definition: VLA-PUT
Message 16 of 18
kerry_w_brown
@BriamR
Re :
Command: LTOD
1 found
I'd surmise you have a redundant space in one of the function names.
Perhaps do a search for VLA-PUT<space> for the culprit.
Re:
; error:
Perhaps you wanted VLA-PUT-PROPERTY  ??
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 17 of 18
hosneyalaa
@BriamR  test
(defun c:TESSTDLinkv (/ )
(vl-load-com)
  (vl-load-com)
      (progn
	(exit)
(setq ent1 (car (entsel "\nSelect entity ")))
  (vlax-for  LT LTs
 (setq Count  0
  (setq rs nil)
  (setq Values  (printFieldValues rs nil))
  (setq hh  0)
(repeat (length Values)
    (princ (nth hh Values))
  (princ  "\n")
  (princ  "\n")
  (setq hh  (+ 1 hh))
  (princ  "\n")
  (princ  "\n")
  (if adoConnect
	padStr         "")
	fieldsIndex 0)
    (if bPrint
	  fieldsIndex 0
	  strOneRow nil)
    (if bPrint
	(progn
	  (princ "\n")
Message 18 of 18
BriamR
I am still trying and I am getting closer. I managed to show the key field "INTERNO_DEMARCACION" but I still can't show the corresponding field "CLASE DEMARCACION", I am still working on transferring these values in the object data, thank you for any help.
I share the code I am working on:
(defun c:LTOD (/ acad doc ss obj linkTemplates dbConnect gCmnFiles gCaoTlb gADO-DLLpath linkTemplate)
  (vl-load-com)
  ;; Obtener el objeto de AutoCAD y el documento activo
  (setq doc (vla-get-ActiveDocument acad))
  ;; Ruta de las bibliotecas necesarias
  ;; Verificar la existencia de la biblioteca ADO
    (progn
      (exit)
  ;; Importar la biblioteca de tipos ADO
  (if (null adok-adStateOpen)  ;; Verificar que la biblioteca de tipos ADO no se haya cargado aún
                              :constants-prefix "adok-"))
  ;; Importar la biblioteca de tipos CAO
  (if (null caom-GetLinkTemplates)  ;; Verificar que la biblioteca de tipos CAO no se haya cargado aún
                              :constants-prefix "caok-"))
  ;; Obtener el objeto y su ID
  ;; Crear el objeto DbConnect
  ;; Obtener los link templates
  (setq linkTemplates (vlax-invoke-method dbConnect "GetLinkTemplates"))
  (vlax-for LT linkTemplates
        (setq lA_Obj_IDS (cons thisLink lA_Obj_IDS))
  (setq linkTemplate (car lA_Obj_IDS))
  (setq linkTemplatename (vlax-get-property (vlax-get-property linkTemplate "LinkTemplate") "Name"))
  ;; Obtener valor de INTERNO_DEMARCACION desde el link template
  (setq thisKeyValue (vlax-invoke-method (vlax-get-property linkTemplate "KeyValues") "Item" 0))
  ;; Conectar a la fuente de datos
  (defun cmdConnectDataSource_Click (linkTemplate / strDataSourceLoc strDataSource currConnectionString)
          strDataSource (vlax-get-property (vlax-get-property linkTemplate "LinkTemplate") "DataSource"))
    (if adoConnect
    (setq ADOConnect (vlax-create-object "ADODB.Connection"))
    (setq currConnectionString (strcat "File Name=" strDataSourceLoc strDataSource ".udl;User ID=;Password=;"))
  ;; Preparar el comando ADO
  (setq cmd (vlax-create-object "ADODB.Command"))
  (vlax-put-property cmd "CommandText" (strcat "SELECT * FROM " (vlax-get-property (vlax-get-property linkTemplate "LinkTemplate") "Table")))
  ;; Abrir el Recordset
  (vlax-invoke-method rs "Open" cmd nil adok-adOpenDynamic adok-adLockBatchOptimistic adok-adCmdUnknown)
  ;; Buscar la fila correspondiente a INTERNO_DEMARCACION
  (vlax-invoke-method rs "MoveFirst")
  (setq found nil)
  (while (and (not (vlax-get-property rs "EOF")) (not found))
    (setq fields (vlax-get-property rs "Fields"))
    (setq fieldInterno (vlax-invoke-method fields "Item" 0))
    (setq internoValue (vlax-variant-value (vlax-get-property fieldInterno "Value")))
    (if (= thisValue internoValue)
      (setq found t)
      (vlax-invoke-method rs "MoveNext"))
  (if found
    (progn
      ;; Obtener el valor de CLASE_DEMARCACION
      (setq fieldClase (vlax-invoke-method fields "Item" 1))
      (setq claseValue (vlax-variant-value (vlax-get-property fieldClase "Value")))
    (setq claseValue "No encontrado")
  ;; Copiar los valores a Object Data
  (setq tn "SDM_DEM_DEMARCACION")
  (ade_odaddrecord tn)
  (ade_odsetfield ent1 tn "INTERNO_DEMARCACION" (vl-princ-to-string thisValue))
  (ade_odsetfield ent1 tn "CLASE_DEMARCACION" (vl-princ-to-string claseValue))
  ;; Mostrar resultados
  (princ (strcat "\n" (itoa (vlax-get-property rs "RecordCount")) " Rows\n"))
  (princ (strcat "INTERNO_DEMARCACION: " (vl-princ-to-string thisValue) "\n"))
  (princ (strcat "CLASE_DEMARCACION: " (vl-princ-to-string claseValue) "\n"))
  (princ)
