switch layout1 to layout2,and then layout3...
Dear All Guys:
I have a multi layout file, i want do something in layout1, switch to layout2,do something, and then  switch to layout3...
what i can do? i don‘t know how to switch layout.
_gile
You can use the CTAB system variable:
Application.SetSystemVariable("CTAB", "Layout2");
Gilles Chanteau
GileCAD
GitHub
Dear Sir:
My problem is I have 4 layouts, I want insert some information(eg.text) in each layout, but the following code only can insert it to first layout,
how to insert it to the others layout?
// Open the Block table for read
      BlockTable acBlkTbl;
      acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId,
                                   OpenMode.ForRead) as BlockTable;
      // Open the Block table record Paper space for write
      BlockTableRecord acBlkTblRec;
      acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.PaperSpace],
                                      OpenMode.ForWrite) as BlockTableRecord;
         DBText acText = new DBText();
          acText.Position = acPtIns;
          acText.Height = 0.5;
          acText.TextString = "test";
          acBlkTblRec.AppendEntity(acText);
          acTrans.AddNewlyCreatedDBObject(acText, true);
_gile
You can access layouts from the layout dictionary and get each layout (except "Model") BlockTableRecord.
            using (Transaction tr = db.TransactionManager.StartTransaction())
                var layoutDict = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
                foreach (DBDictionaryEntry entry in layoutDict)
                    if (entry.Key != "Model")
                        var layout = (Layout)tr.GetObject(entry.Value, OpenMode.ForRead);
                        var btr = (BlockTableRecord)tr.GetObject(layout.BlockTableRecordId, OpenMode.ForWrite);
                        var text = new DBText();
                        text.Position = insPt;
                        text.Height = 0.5;
                        text.TextString = "test";
                        btr.AppendEntity(text);
                        tr.AddNewlyCreatedDBObject(text, true);
                tr.Commit();
Gilles Chanteau
GileCAD
GitHub
