moveGripPointsAt doesnt work with some objects + edit Curve points question
5thSth
5thSth
I've tried to code a script that would reposition all selected grip points according to a function;
It works like a charm on polylines;
but it hits a snag on many other objects;
on lines it does not move points (even though correct input happens)
and on splines it pops an unhandled exception error;
can someone clarify this behaviour for me? Or propose an alternative method?
while on the subject; can someone shed light on how to readjust "Curve point" using the curve point properties? Since I wasnt able to find a "Point3dcollection that would correspond to its points?"
                foreach (GripData grip in grips)
                    if (gripCounter % 2 == 0) //skip midpoints
                        Point3d oldPos = grip.GripPoint;
                        Point3d newPos = adjustPoints3d(oldPos);
                        Vector3d offsetPart = newPos - oldPos;
                        GripDataCollection gripsTemp = new GripDataCollection();
                        gripsTemp.Add(grip);
                        ent.MoveGripPointsAt(gripsTemp, offsetPart, MoveGripPointsFlags.Polar);
5thSth
addition; Ive realized grip initalization might be important as well.. so here's how I do it.
I've gotten better results when using GetGripPointFlags.CyclableGripsOnly; with Splines... but "Line" still doesnt move.
     GripDataCollection grips = new GripDataCollection();
                    double curViewUnitSize = 0; int gripSize = 0;
                    Vector3d curViewDir = doc.Editor.GetCurrentView().ViewDirection;
                    GetGripPointsFlags bitFlags = GetGripPointsFlags.GripPointsOnly;
                    var xx = ent.GetGripPoints(grips, curViewUnitSize, gripSize, curViewDir, bitFlags);
