Specifying .config file with entity framework
deusextechnic
deusextechnic
Hi, I am using entity framework code first approach to write/read to a database from autocad.net. I have a solution whereby I am adding the database connection string to the acad.exe.config file contained in autocad root in Program files. This is not really an elegant solution and is causing me issues with access. Is there a way I can point my DBContext derived class to a .config residing inside the plugin rather than acad.exe.config?
nagamalliv
Please add App.config to your application, if you build the application .config should be present in the release folder(in release mode).
Ed__Jobe
You will want to read this thread.
Ed
How to post your code.
