SPECIFIC documentation for AutoCad .NET API - methods, classes, properties....??
BKSpurgeon
BKSpurgeon
Hi folks
I am a little lost.
I have tried:
  • Autocad .net developer's guide - downloaded from the ADN site
  • ObjectARX developer's guide - downloaded from the ADN site
  • the internet
.......and am still lost, so I thought I will ask the forum.
Suppose I am reading the ObjectARX documentation. There is something I don't understand there:
"Struct resbuf *pointlist"
When I see something in C# which I don't understand, I go to the MSDN library and type it in and get ready answers .eg the ToString method: https://msdn.microsoft.com/en-us/library/system.object.tostring(v=vs.110).aspx
i get clear explanations as to what it is, what it does, examples, notes, and also any parameters and properties applicable.
Where can I do the same in autocad? I am seeing a darth of readily available information about what things are: e.g. what ads_name is and so on.
Where can I learn about what particular autocad methods/classes and functions do?
Any help/advice will be appreciated, and you will be sparing someone a lot of grief too. thank you for your help.
regards
BK
FRFR1426
The documentation of the managed API is in the ObjectARX documentation, in the file arxmgd.chm. There is also a dedicated section in arxdev.chm (Using .NET for AutoCAD Development)
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
dgorsman
"Struct resbuf *pointlist" sounds like its from the unmanaged C++ documentation, not the managed dotNET documents.
Granted, they could be a little bit better but unlike the MSDN documentation there is an assumption (and a valid one) that the reader is familiar with the programming methods being employed, whereas the MSDN documentation is covering from the ground up to that point.
If it existed you would of found it by now. The documentation is not very good, and needs a alot of resources thrown at it to update it.
It was diffucult for me and wasted alot time that could of been saved where I made assumptions.
BKSpurgeon
thank you sir, i have found it!
[the expalantions in the .chm files aren't the greatest, granted, but they are better than not having them at all.]
and for those looking for answer - go to: C:\ObjectARX 2015\docs to find the chm files FRF1426 mentions.
and then you will find the .chm files.
rgds
BK
BKSpurgeon
thank you sir.
BKSpurgeon
thanks for the site!!! i will go there when looking for answers!
