Editor.Command and Layer....
ok. I'm trying to use the editor.command method. it's in a modal command but is being called from events like "newFocus" or "layoutswitched".
still, I'm confused on why I get eInvalidInput no matter what I try.
if
ed=doc.editor
dim layname as string = layerToBeSwitchedOn
then I've tryied:
Ed.Command("_.-LAYER", "ON", LayerName)
Ed.Command("_.-LAYER", "ON", LayerName,"","")
Ed.Command("_.-LAYER", "ON", LayerName,vbcr,vbcr)
Ed.Command("_.-LAYER", "ON", LayerName,vblf,vblf)
Ed.Command("-LAYER", "ON", LayerName)
Ed.Command("-LAYER", "ON", LayerName,"","")
Ed.Command("-LAYER", "ON", LayerName,vbcr,vbcr)
Ed.Command("-LAYER", "ON", LayerName,vblf,vblf)
apparently, none of which is valid. please explain?
also tried,
Ed.Command("_.-LAYER", "ON", LayerName,"")
Ed.Command(new Object() {"_.-LAYER", "ON", LayerName,""})
Ed.Command(new Object() {"_.-LAYER", "ON", LayerName,"",""})
just, cause.
also tried it as a session command.
gave up, did it though non command line code.
