使用 ReadDwgFile 获取 Database ,修改其中的DBText 与 AttributeReference 发生对齐及宽度因子不改变。
a932994040
Message 1 of 9
a932994040
想请教一下,我使用 ReadDwgFile 获取 Database ;
使用 Transaction 获取 Database 中的 DBText 与 AttributeReference;
对其属性 TextString 进行修改;
但只修改了文本值,对齐方式与宽度因子未随之改变;
尝试使用 AdjustAlignment,但并未解决问题。
using (var docLock = document.LockDocument())
using(var ndb = new Database(false, true))
ndb.ReadDwgFile("D:\\Projects\\Document3.dwg", FileShare.ReadWrite, true, "");
using (Transaction tr = ndb.TransactionManager.StartTransaction())
var bt = tr.GetObject(ndb.BlockTableId, OpenMode.ForRead) as BlockTable;
var btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
foreach (ObjectId id in btr)
var dbo = tr.GetObject(id, OpenMode.ForWrite);
if (dbo.GetType() == typeof(DBText))
txt = dbo as DBText;
txt.TextString = "填充文本";
var originalDatabase = HostApplicationServices.WorkingDatabase;
HostApplicationServices.WorkingDatabase = ndb;
txt.AdjustAlignment(ndb);
HostApplicationServices.WorkingDatabase = originalDatabase;
tr.Commit();
ndb.SaveAs("D:\\Projects\\Document3.dwg", DwgVersion.Current);
ndb.Dispose();
I borrowed from previous posts:
https://forums.autodesk.com/t5/net/attrubute-text-alignment-problem-after-update/m-p/2624675#M17532
https://forums.autodesk.com/t5/net/wrong-justification-of-dbtext-in-block/m-p/9401872/highlight/fals...
https://forums.autodesk.com/t5/net/c-dbtext-alignment-error-when-openning-readdwgfile-method-have/m-...
use code:
no success
Must the DWG file be opened in a viewport to take effect?
Replies (8)
Message 2 of 9
norman.yuan
Well, I would try to set WorkingDatabase BEFORE starting the Transaction:
using (ndb=new Database(false, true))
  ndb.ReadDwgFile(...);
  var originalDatabase=HostApplicationServices.WorkingDatabase;
  using (var tr = ndb.TransactionManager.StartTransaction()
    tr.Commit();
  HostApplicationServices.WorkingDatabase=originalDatabase
  ndb.SaveAs(...)
Norman Yuan
Drive CAD With Code
Message 3 of 9
a932994040
I followed your method to try to set WorkingDatabase BEFORE starting the Transaction
original document:
After program execution:
Manual movement:
					txt.SetDatabaseDefaults(ndb);
					txt.TextString = "红旗H平台";
			tr.Commit();
		ndb.Dispose();
Message 4 of 9
Miralkong
Hi, in my test, I found that if you set the command flag to CommandFlags.Session, it works well. The sample code is as below:
[CommandMethod("test",CommandFlags.Session)]
        public void Test()
            Database sourceDb = new Database(false, true);
            sourceDb.ReadDwgFile("Your dwg file path", System.IO.FileShare.ReadWrite, true, "");
            sourceDb.CloseInput(true);
            var originalDb = HostApplicationServices.WorkingDatabase;
            using (Transaction acTrans = sourceDb.TransactionManager.StartOpenCloseTransaction())
                HostApplicationServices.WorkingDatabase = sourceDb;
                BlockTable acBlkTbl = acTrans.GetObject(sourceDb.BlockTableId, OpenMode.ForWrite) as BlockTable;
                BlockTableRecord acBlkTblRec = acTrans.GetObject(acBlkTbl[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                foreach (ObjectId id in acBlkTblRec)
                    DBObject obj = acTrans.GetObject(id, OpenMode.ForWrite);
                    if (obj.GetType() != typeof(DBText))
                        continue;
                    DBText txt = (DBText)obj;
                    txt.TextString = "Change text from dll";
                    txt.Height = 5000;
                    txt.WidthFactor = 5;
                    txt.Justify = AttachmentPoint.MiddleCenter;
                    txt.AlignmentPoint = txt.Position;
                acTrans.Commit();
            HostApplicationServices.WorkingDatabase = originalDb;
            sourceDb.SaveAs("Your dwg file path", DwgVersion.Current);
            sourceDb.Dispose();
Message 5 of 9
a932994040
Thanks! That was it.
Message 6 of 9
a932994040
Hello, I want to replicate a BlockReference and modify the TextString attribute value of AttributeReference in the replicated BlockReference。I applied the same method to AttributeReference, but the position did not refresh。Could you please guide me again? Thank you very much!
[CommandMethod("test", CommandFlags.Session)]
public void Test()
	sourceDb.ReadDwgFile("D:\\Projects\\Document2.dwg", System.IO.FileShare.ReadWrite, true, "");
		BlockReference block = null;
			if (obj.GetType() != typeof(BlockReference))
				continue;
			block = (BlockReference)obj;
		var point = new Point3d(block.Position.X + 260, block.Position.Y, block.Position.Z);
		var mt = Matrix3d.Displacement(point - block.Position);
		var nbr = block.GetTransformedCopy(mt) as BlockReference;
		acBlkTblRec.AppendEntity(nbr);
		acTrans.AddNewlyCreatedDBObject(nbr, true);
		foreach (ObjectId id in nbr.AttributeCollection)
			var nbr_ar = acTrans.GetObject(id, OpenMode.ForWrite) as AttributeReference;
			switch (nbr_ar.Tag)
				case "厂项名称":
					nbr_ar.TextString = "红旗H平台";
					break;
				case "图纸名称":
					nbr_ar.TextString = "蜡烘干室";
					break;
				case "图纸编号":
					nbr_ar.TextString = "FH866";
					break;
				case "年":
					nbr_ar.TextString = "2023";
					break;
				case "月":
					nbr_ar.TextString = "5";
					break;
			nbr_ar.AdjustAlignment(sourceDb);
		acTrans.Commit();
	sourceDb.SaveAs("D:\\Projects\\Document2.dwg", DwgVersion.Current);
	sourceDb.Dispose();
Message 7 of 9
a932994040
Hello, I have reviewed the post about updating attribute references but have not found a solution. Can you help me?
Message 8 of 9
a932994040
I refer to other similar solutions, which are all copying the AttributeDefinition of the original BlockReference and recreating the BlockReference before adding a new AttributeDefinition;
Message 9 of 9
Miralkong
Hi. The reason why you did't get a correct result is that you should call "attsync" method after you change the contents of an attribute block. However, if you are working with a side database, you probably can't use Editor.Command("_attsync ", "_name ", "your block name"). Another way you could try is to create a new block reference other than copying one and editing its value. Another thing to say here, the method you used in your code to get the attribute block can only work on the circumstance that you only have one block in your drawing. You should use more general ways to do it. Below is a sample that works on my computer.
        public void Test()
            sourceDb.ReadDwgFile(@"C:\Users\MiralKong\Desktop\Document2.dwg", System.IO.FileShare.ReadWrite, true, "");
                string attBlkName = "汇总封面块";
                BlockTable acBlkTbl = acTrans.GetObject(sourceDb.BlockTableId, OpenMode.ForRead) as BlockTable;
                Point3d insertPt = new Point3d();
                    BlockReference origin = acTrans.GetObject(id, OpenMode.ForRead) as BlockReference;
                    if(origin!=null && origin.Name == attBlkName)
                        insertPt = origin.Position;
                        break;
                insertPt = new Point3d(insertPt.X + 260, insertPt.Y, insertPt.Z);
                if (!acBlkTbl.Has(attBlkName))
                    return;
                BlockTableRecord attBlkTblRec = acTrans.GetObject(acBlkTbl[attBlkName], OpenMode.ForRead) as BlockTableRecord;
                using (BlockReference acBlkRef = new BlockReference(insertPt, attBlkTblRec.ObjectId))
                    acBlkTblRec.AppendEntity(acBlkRef);
                    acTrans.AddNewlyCreatedDBObject(acBlkRef, true);
                    foreach (ObjectId id in attBlkTblRec)
                        DBObject dBObject = acTrans.GetObject(id, OpenMode.ForWrite);
                        AttributeDefinition attDef = dBObject as AttributeDefinition;
                        if (attDef != null && !attDef.Constant)
                            using (AttributeReference attRef = new AttributeReference())
                                attRef.SetAttributeFromBlock(attDef, acBlkRef.BlockTransform);
                                switch (attDef.Tag)
                                    case "厂项名称":
                                        attDef.TextString = "红旗H平台";
                                        break;
                                    case "图纸名称":
                                        attDef.TextString = "蜡烘干室";
                                        break;
                                    case "图纸编号":
                                        attDef.TextString = "FH866";
                                        break;
                                    case "年":
                                        attDef.TextString = "2023";
                                        break;
                                    case "月":
                                        attDef.TextString = "5";
                                        break;
                                acBlkRef.AttributeCollection.AppendAttribute(attRef);
                                acTrans.AddNewlyCreatedDBObject(attRef, true);
                acTrans.Commit();
            sourceDb.SaveAs(@"C:\Users\MiralKong\Desktop\Document2.dwg", DwgVersion.Current);
            sourceDb.Dispose();
