VB.NET Adding multiple dwg files to a new drawing
david_jamesM529C
Message 1 of 1
david_jamesM529C
Community Visitor
Community Visitor
I wonder if someone can help with the following:
Scenario: I have a folder with multiple .dwg files in it, (up to 40 in some cases). They need to be added to a new drawing file as layers with the end result being as in screenshot titled "ACad drawing grid view". I have code gleaned from this forum to add layers to the file but it it doesn't work. I am not sure whether I should be adding layers or blocks or whether is can be achieved at all using the API.
The code currently iterates through the .dwg files in the folder and
option 1 - extracts the layers from the drawing and runs a procedure to add them to the new drawing (result is nothing is added)
Private Shared Function GetLayersFromDrawing(ByVal sourceFile As String, curDoc As Document) As IList(Of LayerTableRecord)
If String.IsNullOrEmpty(sourceFile) Then Throw New ArgumentNullException("sourceFile")
If Not File.Exists(sourceFile) Then Throw New FileNotFoundException(sourceFile)
If curDoc Is Nothing Then Throw New ArgumentNullException("MdiActiveDocument")
Dim sourceLayers = New List(Of LayerTableRecord)()
Dim layer As LayerTableRecord
Try
Dim sourceDb = New Database(True, False)
sourceDb.ReadDwgFile(sourceFile, FileOpenMode.OpenForReadAndAllShare, False, Nothing)
Using trans = sourceDb.TransactionManager.StartOpenCloseTransaction()
Dim layerTable = CType(trans.GetObject(sourceDb.LayerTableId, OpenMode.ForRead), LayerTable)
For Each layerId In layerTable
layer = CType(trans.GetObject(layerId, OpenMode.ForRead), LayerTableRecord)
If layer.Name <> "0" Then
sourceLayers.Add(layer)
Next
trans.Commit()
End Using
Catch acex As Autodesk.AutoCAD.Runtime.Exception
System.Diagnostics.Debug.Write(acex.Message)
'logger.LogErr("OPES.ERR", ex.Message, ex.StackTrace.ToString)
End Try
Return sourceLayers
End Function
Private Shared Sub AddLayersToCurrentDrawing(ByVal layerList As IList(Of LayerTableRecord), ByRef curDoc As Document, ByRef curDb As Database)
If layerList Is Nothing Then Throw New ArgumentNullException("layerList")
If layerList.Count = 0 Then Throw New ArgumentOutOfRangeException("layerList")
'Dim curDoc = Application.DocumentManager.MdiActiveDocument
'Dim curDb = curDoc.Database
Try
Using trans = curDb.TransactionManager.StartOpenCloseTransaction()
Dim layerTable = CType(trans.GetObject(curDb.LayerTableId, OpenMode.ForWrite), LayerTable)
For Each layer In layerList
If layerTable.Has(layer.Name) Then Continue For
layerTable.Add(layer)
trans.AddNewlyCreatedDBObject(layer, True)
Next
trans.Commit()
End Using
Catch ex As Autodesk.AutoCAD.Runtime.Exception
System.Diagnostics.Debug.Write(ex.Message)
curDoc.Editor.WriteMessage(ex.Message)
End Try
End Sub
option 2 - extracts blocks and adds them to the new drawing file, (result is one set of layers is added, appears to be a random file in the folder, see "ACad block import result").
Public Sub ImportBlocks(doc As Document, srcFile As String)
Dim destDb As Database = doc.Database
Dim sourceDb As Database = New Database(False, True)
Try
sourceDb.ReadDwgFile(srcFile, System.IO.FileShare.Read, True, "")
Dim blockIds As ObjectIdCollection = New ObjectIdCollection()
Dim tm = sourceDb.TransactionManager
Using myT = tm.StartOpenCloseTransaction()
Dim bt As BlockTable = CType(myT.GetObject(sourceDb.BlockTableId, OpenMode.ForRead, False), BlockTable)
For Each btrId As ObjectId In bt
Dim btr As BlockTableRecord = CType(myT.GetObject(btrId, OpenMode.ForRead, False), BlockTableRecord)
If Not btr.IsAnonymous AndAlso Not btr.IsLayout Then blockIds.Add(btrId)
btr.Dispose()
Next
End Using
Dim mapping = New IdMapping()
sourceDb.WblockCloneObjects(blockIds, destDb.BlockTableId, mapping, DuplicateRecordCloning.Replace, False)
logger.LogErr("OPES.ERR", ex.Message)
End Try
sourceDb.Dispose()
End Sub
I hope I've explained this well enough. Would be grateful of some help here.
Many thanks.
Replies (0)
