Set current textstyle
Ok having a dumb day, I can create my textstyle no problem, the issue im having is setting the textstyle current. There is a cLayer property for layers but how on earth do I do it with textstyles.
As always any help much appreciated.
TEXTSTYLE system variable.
that will do it. Ok how would I set the dimstyle then because the dimstyle sysVar is readonly?
If you're going the ActiveX / COM route, use (document).ActiveDimStyle to set it.
Otherwise, if you're doing managed .NET, I'm not sure.
I haven't tried to tackle that with the managed API yet.
But, if I come across the solution, I'll post it.
DimStyleTableRecord dsr = new DimStyleTableRecord();
trans.AddNewlyCreatedDBObject(dsr, true);
db.Dimstyle = dsr.ObjectId;
after your dimstyle is created (or if it already exists):
then you can set the
db.Dimstyle = (the ObjectId of your newly created or existing dimstyle record from the DimStyleTableRecord.
I think that when you call db.Dimstyle = dsr.ObjectId; the settings for that dimstyle are set to the associated
system variables. Until I got the db.Dimstyle = dsr.ObjectId; part figured out, I noticed that I had the dimstyle
set but I always ended up using a "motified" version of the dimstyle.
Here is a code snippet to achief your goal. It is for setting a dimstyle curent but it works te same for a text style. read the command at the end:
C# code
private void SetDimStyle(string dimStyleName)
Database db = HostApplicationServices.WorkingDatabase;
using (Transaction trans = db.TransactionManager.StartTransaction())
DimStyleTable DimTabb = (DimStyleTable)trans.GetObject(db.DimStyleTableId, OpenMode.ForRead);
if (DimTabb.Has(dimStyleName))
DimStyleTableRecord DimTabbRecaord = (DimStyleTableRecord)trans.GetObject(DimTabb[dimStyleName], OpenMode.ForRead);
if (DimTabbRecaord.ObjectId != db.Dimstyle)
db.Dimstyle = DimTabbRecaord.ObjectId;
//A similar method might not be needed in the case of text style setting a similar property as above should be enough
db.SetDimstyleData(DimTabbRecaord);
VB.NET Code
Private Sub SetDimStyle(ByVal dimStyleName As String)
Dim db As Database = HostApplicationServices.WorkingDatabase
Using trans As Transaction = db.TransactionManager.StartTransaction()
Dim DimTabb As DimStyleTable = DirectCast(trans.GetObject(db.DimStyleTableId, OpenMode.ForRead), DimStyleTable)
If DimTabb.Has(dimStyleName) Then
Dim DimTabbRecaord As DimStyleTableRecord = DirectCast(trans.GetObject(DimTabb(dimStyleName), OpenMode.ForRead), DimStyleTableRecord)
if DimTabbRecaord.ObjectId <> db.Dimstyle Then
'A similar method might not be needed in the case of text style setting a similar property as above should be enough
End If
End If
End Using
End Sub
Hope this snippet helps you to solve your problem. Edited by: Irvin on May 12, 2009 1:25 PM
