SendCommand execute after Form close.
Message 1 of 8
Hi
 On Command Method in my plugin i load a form using following call.
Autodesk.AutoCAD.ApplicationServices.Application.ShowModalDialog(form);
 When form loads on a button click event i call  ActiveDocument.Utility.GetPoint  to get a point on my dwg.
After getting ther point in button click event i call ActiveDocument.SendCommand to create new TextStyle.
SendCommand dont work until i close my form. after closing form commandline ask for textstyle params.
Is there any way i can run SendCommand when my form is on screen.
thanks
Replies (7)
Message 2 of 8
_gile
SendCommand (as SendStringToExecute) runs asynchronously.
To synchronously run a command:
- targeting AutoCAD 2015 or later, you can use the Editor.Command method (see here and there) ;
- for pior versions, you'd need to P/Invoke acedCmd or call the non public Editor.Command() method.
You can also create a new TextStyleTableRecord and add it to the TextStyleTable programatically (see here).
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 3 of 8
Hi Gilles
Thanks for your reply.
i have problem using Editor command method every time i call it throw exception on line
Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.IsApplicationContext
which is always true.
tried with CommandFlags.Session and without it no diffrence.
Message 4 of 8
try use this
Autodesk.AutoCAD.ApplicationServices.Application.ShowModelessDialog (MyForm);
Message 5 of 8
no diffrence weather its modal or Modeless dialog.
Message 6 of 8
Ok, can you show your code?
Message 7 of 8
Autocad2014 with .net 4
here is my code very simple.
public class NavPlugin : IExtensionApplication
        public void Initialize()
        public void Terminate()
            throw new NotImplementedException();
        [CommandMethod("SNDCMD")]
        public static void sendCmd()
            var form = new MyForm();
            Application.ShowModelessDialog(form);
public partial class MyForm : Form
        public MyForm()
            InitializeComponent();
        private void BtnSendCmdClick(object sender, EventArgs e)
            var doc = AcAp.DocumentManager.MdiActiveDocument;
            Editor ed = doc.Editor;
            ed.Command("_line", new Point2d(0, 0), new Point2d(500, 500));
            ed.WriteMessage("test.");
Message 8 of 8
_gile
while using modeless dialog, you have to lock the document before you modify it.
Gilles Chanteau
GileCAD
GitHub
