Programatically Export DWG to IGS in 2016?
mtwohig
mtwohig
Is there any way to programatically export a DWG to IGS? We have AutoCAD 2016 and I'm developing in VB.Net.
I've seen a couple other article using older Acad versions and Aruba.exe, but they didnt work for me... namely because Aruba.exe apparently doesnt come with Acad 2016.
FRFR1426
aruba.exe has been replaced by acTranslators.exe. Here is some code for 2014/2015:
Dim cultureName As String = Thread.CurrentThread.CurrentCulture.Name
Dim acadVersion As String = HostApplicationServices.Current.releaseMarketVersion & ".0.0.F"
#If ACAD2014 Then
  Const PRODUCT_KEY As String = "001F1"
#ElseIf ACAD2015 Then
  Const PRODUCT_KEY As String = "001G1"
#End If
Dim licenseTypeAsString As String = "SA" ' Stand Alone
Dim productGlobalRootKey As String = HostApplicationServices.Current.MachineRegistryProductRootKey.Substring(0, _
  HostApplicationServices.Current.MachineRegistryProductRootKey.Length - 4)
Dim licenseTypeAsInt As Integer = Microsoft.Win32.Registry.GetValue("HKEY_LOCAL_MACHINE\" & productGlobalRootKey & "AdlM", "Type", 2)
' 1 - Network
' 2 - Standalone
' 3 - Multiseat Standalone
If licenseTypeAsInt = 1 Then
    Dim acadLocation As String = Microsoft.Win32.Registry.GetValue("HKEY_LOCAL_MACHINE\" & _
      HostApplicationServices.Current.MachineRegistryProductRootKey, "AcadLocation", "")
    If "" = acadLocation Then
        Throw New ApplicationException("Read of acad location failed")
    licenseTypeAsString = "NW -productLicensePath """ & acadLocation & """"
Dim startInfo As New ProcessStartInfo(translatorFullPath, String.Format("-productKey {0} -productVersion {1} -productLicenseType {2}" & _
  " -productResourcePath ""{3}"" -productLicenseLocale {4} -i ""{5}"" -o ""{6}""", PRODUCT_KEY, acadVersion, licenseTypeAsString, _
  Path.Combine(acadDir, "AdlmRes\" & cultureName), cultureName.Replace("-", "_"), inputFullPath, outputFullPath))
startInfo.CreateNoWindow = True
startInfo.RedirectStandardOutput = True
startInfo.UseShellExecute = False
Dim proc As Process
Try
    proc = Process.Start(startInfo)
Catch ex As Win32Exception
  If ex.ErrorCode = &H80004005 Then
    Throw New ApplicationException(String.Format("Program {0} not found.", translatorFullPath))
  Else
    Throw
End Try
proc.WaitForExit()
Dim errors As String = proc.StandardOutput.ReadToEnd()
If Not String.IsNullOrEmpty(errors) Then
  Throw New ApplicationException(errors)
If proc.ExitCode <> 0 Then
  Throw New ApplicationException(String.Format(Extension.StringResources("ImportFailed"), inputFullPath))
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
mtwohig
Thank you, sir.
I will try this when I get a chance... hopefully by tomorrow night.
hi
I am having a problem like above but i read your cmt i don't understand
Can you give me the code of a program that outputs the igs file from the dwg file?
I thank you very much
