AutoCAD 2014, C# call AddHatch throw exception
I use Auto CAD 2014, by in the follow code throw exception error,  I donot why, pls help me
private void button4_Click(object sender, EventArgs e)
AcadApplication app = new AcadApplicationClass();
app.Documents.Open(this.textBox1.Text, missing, missing);
app.Visible = false;
IAcadHatch hatch = app.ActiveDocument.ModelSpace.AddHatch(1, "ANSI31", true);
// inner loop
object[] inloop = new object[1];
AcadCircle circle = app.ActiveDocument.ModelSpace.AddCircle(new double[] { 100, 100, 0 }, 200);
inloop[0] = circle;
hatch.AppendInnerLoop(inloop);  // <====== in here: Invalid object array
string file = string.Format(@"{0}Demo_{1}.dwg", AppDomain.CurrentDomain.BaseDirectory, System.Guid.NewGuid());
app.ActiveDocument.SaveAs(file, AcSaveAsType.ac2010_dwg, missing);
app.Quit();
norman.yuan
The AcadHatch.AppendInner[Outer]Loop() method takes an OBJECT (Variant in COM world), not an OBJECT ARRAY as input. That is:
object inLoop=new XXXXX[]{xxx, xxx, xxx};
is different from
object[] inLoop=new XXXXX[]{xxx, xxx, xxx};
So, this code works OK:
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using CadApp = Autodesk.AutoCAD.ApplicationServices.Application;
using CadDb = Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
[assembly: CommandClass(typeof(ComHatchTest.Commands))]
namespace ComHatchTest
    public class Commands
        [CommandMethod("MyHatch")]
        public static void DoDocumentCommand()
            Document dwg = CadApp.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            try
                DoHatch();
            catch (Autodesk.AutoCAD.Runtime.Exception aex)
                ed.WriteMessage("\nError: {0}", aex.Message);
                ed.WriteMessage("\n*Cancel*");
            catch (System.Exception ex)
                ed.WriteMessage("\nError: {0}", ex.Message);
            finally
                Autodesk.AutoCAD.Internal.Utils.PostCommandPrompt();
        public static void DoHatch()
            AcadApplication app = CadApp.AcadApplication as AcadApplication;
            AcadDocument doc = app.ActiveDocument;
            AcadHatch hatch = doc.ModelSpace.AddHatch(1, "ANSI31", true);
            AcadCircle circle = doc.ModelSpace.AddCircle(new double[] { 100.0, 100.0, 0.0 }, 200.0);
            object inLoop = new AcadEntity[] { circle as AcadEntity };
            hatch.AppendOuterLoop(inLoop);
HTH
Norman Yuan
Drive CAD With Code
I also Encountered the same problem. Then I corrected it follow your code.But when I define the elements of inLoop
as object,It still throws an exception.  Why?
is different from
            try
                DoHatch();
            finally
HTH
