Retrieve info from Block inserted in dwg inserted in another one (XRef
Hello , coninuing from my last post : https://forums.autodesk.com/t5/net/extract-attribut-info-from-a-block-in-a-xref/m-p/6829239#M51769
i need to extract information :
- Position of the block in xref (but position on WCS on the current dwg).
- Scale X or Y or Z of the block in xref (but position on WCS on the current dwg)
i have this code for getting the entity :
Dim opt As PromptNestedEntityOptions = New PromptNestedEntityOptions(vbCrLf & cTexteInfo)
                    opt.AllowNone = False
                    Dim BlocRef As BlockReference = Nothing
retry:
                    Dim prompSelRes As PromptNestedEntityResult
                    Do While (True)
                        prompSelRes = Ed.GetNestedEntity(opt)
                        If (prompSelRes.Status = PromptStatus.Cancel) Then Return "annulation manuelle"
                        Dim entity = tr.GetObject(prompSelRes.ObjectId, OpenMode.ForRead)
                        If TypeOf (entity) Is AttributeReference Then
                            'aquisition du bloc réf
                            BlocRef = tr.GetObject(entity.OwnerId, OpenMode.ForRead)
                            Ed.WriteMessage(vbCrLf & "Nom du bloc (Xref[att]) : " & BlocRef.Name)
                            Exit Do
                        End If
                        Dim containers = prompSelRes.GetContainers()
                        If (containers.Length > 0) Then
                            BlocRef = tr.GetObject(containers(0), OpenMode.ForRead)
                            'Ed.WriteMessage(vbCrLf & "Nom du bloc (Xref) : " & BlocRef.Name)
                            Exit Do
                        End If
                        Ed.WriteMessage(vbCrLf & "L'objet sélectionné n'est pas un bloc.")
                    Loop
with this i have the BlockRef and i can retrieve the BlockDef (see the link above).
but now , how i can check the position in the current drawing ?
i trying : (from  here)
Dim brMat As Matrix3d = Matrix3d.Identity
brMat = brMat.PreMultiplyBy(BlocRef.BlockTransform)
brMat = brMat.PreMultiplyBy(brMat.Inverse())
brMat = brMat.PostMultiplyBy(brMat)
Dim newEnt As Entity = BlocRef.Clone()
newEnt.TransformBy(prompSelRes.Transform.PostMultiplyBy(Matrix3d.Displacement(New Vector3d(0.1, 0.1, 0))))
but this not working and crash if the block have a scale of 1/0.9/0.9  for exemple ...
The .position from the new block is not good too.
can you help me ?
(I need this for create a arc with point1/point  is the location of 2 block in Xref.
ActivistInvestor
retry:
                    Do While (True)
                            Exit Do
                        End If
                            Exit Do
                        End If
                    Loop
can you help me ?
See the Transform property of the PromptNestedEntityResult.
You also cannot use Clone() to copy a BlockReference and its attributes. You should use the Database's DeepCloneObjects() method for that.
