Database.SaveAs Avoid Resetting view
drewj
drewj
I am attempting to batch process multiple dwg's.
I am sideloading the database, then after changes are made I use Database.SaveAs.
The resultant file saves with the modifications, however the saved file has its view reset.
The dwgs view have a Roll Angle to account for a building that is not drawn orthogonally, but this dissapears in the saveas file.
Anyway around this?
Should I be using a different workflow?
Thanks for any guidance
Drew
ActivistInvestor
Anyway around this?
Drew
I'm not sure what Roll Angle means (View Twist?), but I don't seem to have a problem with Database.SaveAs() loosing the current view. When I open a file saved via SaveAs(), even as a side database, the view that was current when the file was last saved in the AutoCAD editor, remains intact.
Is the view that is being lost in a layout viewport or the model tab?
norman.yuan
If the changes made in the processing includes changes to layout (such as changing layout name), then there is a recent discussion here
https://www.theswamp.org/index.php?topic=53680.0
without solution proposed.
Norman Yuan
Drive CAD With Code
