Draw Polyline and place circular block on all the vertex of Polyline
Hi Gilles,
I have a requirement as when the user click on autocad it has to draw polyline and each click on vertexes it should place a uniform size circle blocks.
The screen shot which I have provided below.
Regards
Alex Andrews.
Juergen_Becker
please give this a try:
Parameter:
PointCollection is a Collection of 2D Points
Layer is the layer where the object draws
And don't Forget the usings:
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
public static class ACADPolyLine
        public static void CreatePolyline(Point2dCollection PointCollection, string Layer)
            Autodesk.AutoCAD.ApplicationServices.Document m_Document =
                Autodesk.AutoCAD.ApplicationServices.Core.Application.DocumentManager.MdiActiveDocument;
            using (Transaction m_Transaction = m_Document.Database.TransactionManager.StartTransaction())
                if (PointCollection != null)
                    BlockTable m_BlockTable = (BlockTable)m_Transaction.GetObject(m_Document.Database.BlockTableId, OpenMode.ForRead);
                    BlockTableRecord m_BlockTableRecord =
                        (BlockTableRecord)m_Transaction.GetObject(m_BlockTable[BlockTableRecord.ModelSpace], OpenMode.ForWrite);
                    Autodesk.AutoCAD.DatabaseServices.Polyline m_Polyline = new Polyline()
                        Layer = Layer
                    int i = 0;
                    foreach (Autodesk.AutoCAD.Geometry.Point2d m_Point in PointCollection)
                        m_Polyline.AddVertexAt(i, m_Point, 0, 0, 0);
                        i++;
                        Autodesk.AutoCAD.DatabaseServices.Circle m_Circle = new Circle()
                            Center = new Autodesk.AutoCAD.Geometry.Point3d(m_Point.X, m_Point.Y, 0),
                            Radius = 10,
                            Layer = Layer
                        m_BlockTableRecord.AppendEntity(m_Circle);
                        m_Transaction.AddNewlyCreatedDBObject(m_Circle, true);
                    m_BlockTableRecord.AppendEntity(m_Polyline);
                    m_Transaction.AddNewlyCreatedDBObject(m_Polyline, true);
                m_Transaction.Commit();
I hope thats helps.
Regards Jürgen
I hope my tip helps. If so then give me kudos and mark the tip as a solution.
Thanks.
Jürgen A. Becker
Building Services
Development and Support
Autodesk Forge Spezialist
CAD-Becker.de
https://www.CAD-Becker.de
Thanks Juergen
