publish by vb.net
publish by vb.net
jan_tappenbeck
Message 1 of 1
publish by vb.net
jan_tappenbeck
hi !
alternative to create a pdf-file i try the publish-function by send-command.
my source
 Private Sub PublishRaster()
        Dim acDocument As Autodesk.AutoCAD.ApplicationServices.Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
        Dim cmd As String = String.Format("-publizieren {0} {1}{2}", "X:\PROTOTYP\ebl_map2019_GK4PdfRaster.dsd", Chr(34), Chr(34)) & vbCr
        acDocument.SendStringToExecute(cmd, True, False, True)
    End Sub
but there will not be create a pdf-file. manuell in command line it would be successful!
there will not create a log file.
regards Jan
Replies (0)
