CMDECHO NOMUTT not working
David_Prontnicki
David_Prontnicki
Hi All,
I'm having a problem with CMDECHO and NOMUTT. Have a program that loads or reloads a linetype; found on Dev Blogs. It uses the Send Command option, which obviously writes to the command line. I am getting, setting and restoring the CMDECHO and NOMUTT but it is still writing to the command bar. How do I fully suppress this. I know it's due to the Send Command and that some things like purge cant be suppressed but if works with creating say a text style why not with loading/reloading a linetype?
Called from Form...
Private Sub btnInsert_Click(sender As Object, e As EventArgs) Handles btnInsert.Click
        Try
            Dim selectedLineType As String = lstSelectLinetype.SelectedItem.Filename
            Dim pathHelper As New DetailPathHelper(selectedLineType)
            selectedLineTypeName = pathHelper.LinetypeName
            Dim linetypeFilePath = _clientLinetypeService.FindLinetypeFileForClient(cmbSelectLineTypeFile.Text)
            _autocadSystemVariableServices.StoreSystemVariables()
            _autocadSystemVariableServices.SetSystemVariables()
            _autocadService.LoadLinetype(selectedLineTypeName, linetypeFilePath)
            _autocadSystemVariableServices.RestoreSystemVariables()
        Catch ex As Exception
End Try
End Sub
Sub Called...
Public Class AutocadService
    Implements IAutocadService
    Public Sub LoadLinetype(ByVal selectedLineTypeName As String, ByVal lineTypeFile As String) Implements IAutocadService.LoadLinetype
        Dim acDoc As Document = AutocadActiveDocument.Document
        Dim acCurDb As Database = AutocadActiveDocument.Database
        Dim ltReload As Boolean = False
        Try
            Using acDocLock As DocumentLock = acDoc.LockDocument
                Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
                    Dim acLineTypTbl As LinetypeTable
                    acLineTypTbl = acTrans.GetObject(acCurDb.LinetypeTableId, OpenMode.ForRead)
                    If acLineTypTbl.Has(selectedLineTypeName) = True Then
                        ltReload = True
                    acTrans.Commit()
                End Using
            End Using
            Dim acAppObject As Object = Application.AcadApplication
            Dim acDocObject As Object = acAppObject.GetType().InvokeMember("ActiveDocument", System.Reflection.BindingFlags.GetProperty, Nothing, acAppObject, Nothing)
            Dim sendCommandDataArray As Object() = New Object(0) {}
            If ltReload Then
                sendCommandDataArray(0) = "-linetype Load" & vbLf & selectedLineTypeName & vbLf & lineTypeFile & vbLf & "Yes" & vbLf & " "
            Else
                sendCommandDataArray(0) = "-linetype Load" & vbLf & selectedLineTypeName & vbLf & lineTypeFile & vbLf & " "
            acDocObject.GetType().InvokeMember("SendCommand", System.Reflection.BindingFlags.InvokeMethod, Nothing, acDocObject, sendCommandDataArray)
            sendCommandDataArray(0) = "regenall" & vbLf
End Try
End Sub
System Variable Class...
Public Class AutocadSystemVariableServices
    Implements IAutocadSystemVariableServices
    Dim restoreOldFiledia As Integer
    Dim restoreOldCmdecho As Integer
    Dim restoreOldNomutt As Integer
    Public Sub StoreSystemVariables() Implements IAutocadSystemVariableServices.StoreSystemVariables
        restoreOldFiledia = Convert.ToInt16(Application.GetSystemVariable("FILEDIA"))
        restoreOldCmdecho = Convert.ToInt16(Application.GetSystemVariable("CMDECHO"))
        restoreOldCmdecho = Convert.ToInt16(Application.GetSystemVariable("NOMUTT"))
    End Sub
    Public Sub SetSystemVariables() Implements IAutocadSystemVariableServices.SetSystemVariables
        Application.SetSystemVariable("FILEDIA", 0)
        Application.SetSystemVariable("CMDECHO", 0)
        Application.SetSystemVariable("NOMUTT", 0)
    End Sub
    Public Sub RestoreSystemVariables() Implements IAutocadSystemVariableServices.RestoreSystemVariables
        Application.SetSystemVariable("FILEDIA", restoreOldFiledia)
        Application.SetSystemVariable("CMDECHO", restoreOldCmdecho)
        Application.SetSystemVariable("NOMUTT", restoreOldNomutt)
    End Sub
End Class
norman.yuan
Not sure in what context your code is to run, but since you are doing Acad .NET API coding, why bother using Acad COM API's sendCommand() when you can simply use built-in .NET API functionality:
Database.LoadLineTypeFile()
Norman Yuan
Drive CAD With Code
David_Prontnicki
Thanks Norman,
This is why: https://forums.autodesk.com/t5/net/reload-linetype/td-p/9397842
I am not a fan of send command for this reason and a few others, but I think I am stuck doing it this way....
ActivistInvestor
SendCommand() is asynchronous which means that your system variables are being restored before the commands are executed.
Use the Editor.Command() method instead.
