Plot style is being used but it cannot find my style
Hi all,
I have a routine below that i am using to copy the Plot Styles and layer colors and states in from a list I extracted from my first set up drawing. For whatever reason, I have to go and use each of the styles at least once so that it will find them in the stb file being applied. The funny thing is that at the end, despite me manually and automatically applying the styles, I am able to purge the stb file. Does anyone have any understanding of what i am doing wrong? Any help would be much appreciated as it is driving me around the twist.
  <CommandMethod("ImportLayerStyles")> Public Sub ImportLayerStyles()
        Dim lslist As New List(Of Laystate)
        Dim ls As New Laystate
        Dim errpt As String = "Import plotstyle"
        ' Get the plotstyle
        If db.PlotStyleMode = False Then
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Using hldr As PlaceHolder = New PlaceHolder()
                    Dim d As DictionaryWithDefaultDictionary = CType(tr.GetObject(db.PlotStyleNameDictionaryId, OpenMode.ForWrite), DictionaryWithDefaultDictionary)
                    d.SetAt("MR_Full Size Colour.stb", hldr)
                    tr.Commit()
                End Using
            End Using
        ' open the file
        Dim ofd As New Autodesk.AutoCAD.Windows.OpenFileDialog("Select Template", Nothing, "txt", "PlotStyles", Autodesk.AutoCAD.Windows.OpenFileDialog.OpenFileDialogFlags.DoNotTransferRemoteFiles)
        Dim dr As System.Windows.Forms.DialogResult = ofd.ShowDialog()
        If dr <> System.Windows.Forms.DialogResult.OK Then
            Return
        Dim sName As String = ofd.Filename
        Dim dictLays As New Dictionary(Of String, String)
        Dim sr As StreamReader = New StreamReader(sName)
        Dim line As String
        Try
            errpt = "Writing"
            If System.IO.File.Exists(sName) = True Then
                While sr.Peek() <> -1
                    line = sr.ReadLine()
                    Dim sspl() As String = line.Split("=")
                    ls.sName = sspl(0)
                    ls.sStyle = sspl(1)
                    ls.sFrozen = sspl(2)
                    ls.iColour = sspl(3)
                    lslist.Add(ls)
                End While
                sr.Close()
        Catch ex As System.Exception
            ed.WriteMessage(vbLf & ex.Message)
        End Try
        Dim psmode As Boolean = db.PlotStyleMode
        ' True = ctb, false = stb
        'ed.WriteMessage(vbLf & "PSMODE = {0}", db.PlotStyleMode)
        'ed.WriteMessage(vbLf & "Transaction")
        Try
            Using transaction As Transaction = db.TransactionManager.StartTransaction()
                    Dim symTable As SymbolTable = CType(transaction.GetObject(db.LayerTableId, OpenMode.ForWrite), SymbolTable)
                    For Each id As ObjectId In symTable
                        Dim symbol As LayerTableRecord = CType(transaction.GetObject(id, OpenMode.ForWrite), LayerTableRecord)
                        Dim sLay As String = symbol.Name
                        Dim idLay As ObjectId = Nothing
                        errpt = "Layer " & sLay
                    Dim q = (From l In lslist
                             Where l.sName.Equals(sLay)
                             Select l).First
                    'sw.WriteLine(sLay)
                    Try
                            If Not IsNothing(q) Then
                                Select Case db.PlotStyleMode
                                    Case False : errpt = "Plotstyle " & q.sStyle : symbol.PlotStyleName = q.sStyle
                                End Select
                                errpt = "Freezing Layer " & sLay
                                If q.sFrozen.Equals("F") Then
                                    ed.WriteMessage(vbLf & "Freezing {0}", sLay)
                                    If Not symbol.IsFrozen = True Then symbol.IsFrozen = True
                                errpt = "Colouring Layer " & sLay
                                symbol.Color = Color.FromColorIndex(ColorMethod.ByAci, q.iColour)
                        Catch ex As Autodesk.AutoCAD.Runtime.Exception
                            ed.WriteMessage(vbLf & "Error: " & errpt)
                        End Try
                    Next
                    transaction.Commit()
                End Using
        End Try
    End Sub
deepak.a.s.nadig
The part of the code to create a place holder object and adding it to the plotStyleName dictionary seems ok.
Are you able to see the entry of the plot style in the ACAD_PLOTSTYLENAME dictionary using ARXDBG tool ?
Can you please share non-confidential drawing file to help us investigate more on the issue ?
