Prompt point with ortho mode
youssefGC
youssefGC
Is there a way to control the orthogonal mode at the prompt level?
For example, I retrieve two points (P1, P2), and then I want to retrieve a third point (P3). However, I want to impose a condition: the line formed by P3 and P2 must be perpendicular to the line (P1, P2). Otherwise, I need to enforce the orthogonal mode. Can this be achieved?
ActivistInvestor
Here's an example that was quickly adapted from a jig I've used to obtain a point that lies on any type of Curve. You can use a LineSegment3d as the curve argument to get a point on that line that's perpendicular to the current cursor location.
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Runtime;
namespace AcMgdLib.Geometry
   /// <summary>
   /// Acquires a point that is constrained to be
   /// on a curve, perpendicular/nearest to the
   /// selected point.
   /// </summary>
   public class PointOnCurveJig : DrawJig
      Curve3d curve;
      bool flag = false;
      Point3d last = Point3d.Origin;
      Point3d basePoint;
      string message;
      public PointOnCurveJig(Curve3d curve, string message = null)
         this.curve = curve;
         this.basePoint = curve.StartPoint;
         this.message = message ?? "\nPoint on curve: ";
      /// <summary>
      /// The resulting point on the Curve3d that
      /// was passed to the constructor.
      /// </summary>
      public Point3d PointOnCurve => basePoint;
      /// <summary>
      /// The other endpoint of the perpendicular
      /// line, that was picked by the user.
      /// </summary>
      public Point3d PickedPoint => last;
      protected override SamplerStatus Sampler(JigPrompts prompts)
         var options = new JigPromptPointOptions();
         options.Message = this.message;
         options.UserInputControls = UserInputControls.UseBasePointElevation;
         options.Cursor = CursorType.RubberBand;
         options.UseBasePoint = true;
         options.BasePoint = basePoint;
         PromptPointResult ppr;
         using(new SystemVariable("ORTHOMODE", 0))
            ppr = prompts.AcquirePoint(options);
         if(ppr.Status == PromptStatus.OK)
            last = ppr.Value;
            basePoint = curve.GetClosestPointTo(last).Point;
            return SamplerStatus.OK;
         return SamplerStatus.Cancel;
      protected override bool WorldDraw(WorldDraw draw)
         return true;
      [CommandMethod("POINTONCURVEJIG")]
      public static void PointOnCurveJigExample()
         var doc = Application.DocumentManager.MdiActiveDocument;
         var ed = doc.Editor;
         var peo = new PromptEntityOptions("\nSelect a curve: ");
         peo.SetRejectMessage("\nInvalid, requires a Curve");
         peo.AddAllowedClass(typeof(Curve), false);
         var per = ed.GetEntity(peo);
         if(per.Status != PromptStatus.OK)
            return;
         Curve3d curve3d;
         using(var tr = new OpenCloseTransaction())
            var curve = (Curve)tr.GetObject(per.ObjectId, OpenMode.ForRead);
            curve3d = curve.GetGeCurve();
            tr.Commit();
         var jig = new PointOnCurveJig(curve3d);
         var res = doc.Editor.Drag(jig);
         if(res.Status == PromptStatus.OK)
            using(new SystemVariable("OSMODE", 0))
               ed.Command("._LINE", jig.PointOnCurve, jig.PickedPoint, "");
   public class SystemVariable : IDisposable
      string name;
      object value;
      public SystemVariable(string name, object value)
         this.value = Application.GetSystemVariable(name);
         this.name = name;
         Application.SetSystemVariable(name, value);
      public void Dispose()
         if(value != null)
            value = null;
