Applcation.bundle CUI Problems with Runtime
jdaltonAWVZ3
jdaltonAWVZ3
I have an application.bundle file what has two component sections similar to the ones below. Regardless of where I put the runtime section for either the component section (like below for the CUI) or the CUI component entry section (Like the Labeler .NET example below), Autocad 2024 and below will either load the 2025 and above CUI or not load the CUI at all. This or the entirety of the component section for 2024 does not get loaded. Below is an example of my PackageContents.xml:
<?xml version="1.0" encoding="utf-8"?>
<ApplicationPackage SchemaVersion="1.0" ProductType="Application"
                        Name="CompanyLoader"
                        AppVersion="25.6.0"
                        Description="Load Apps"
                        Author="Josh"
                        Icon="./Contents/Resources/logo icon.ico"
                        HelpFile="./Contents/Resources/help file.html"
                        ProductCode="{0A5133F3-D52D-46FC-A68A-055827DEFE14}">
  <CompanyDetails Name="Name"/>
  <Components>
    <RuntimeRequirements OS="Win64" SeriesMin="R25.0" SeriesMax="R25.0" />
    <ComponentEntry
			ModuleName="./Contents/Resources/newmain.cuix"
			Version="25.0.1"
			AppDescription="CUI File"/>
     <ComponentEntry
			AppName="Labeler From File"
			Version="25.0.2"
			ModuleName="./Contents/Labeler/asbtLabeler.dll"
			AppDescription="Labeler"
			LoadOnCommandInvocation="True"
      AppType=".Net">
      <Commands GroupName="Labeler">
        <Command Local="MHLBF" Global="MHLBF" />
      </Commands>
    </ComponentEntry>
  </Components>
  <Components>
    <RuntimeRequirements OS="Win64" SeriesMin="R20.0" SeriesMax="R24.3" />
    <ComponentEntry
			ModuleName="./Contents-2024/Resources/main-old.cuix"
			Version="24.0.1"
     <ComponentEntry
			AppName="Manhole Labeler From File"
			Version="24.0.1"
			ModuleName="./Contents-2024/Labeler/asbtLabeler.dll"
      AppType=".Net">
      </Commands>
    </ComponentEntry>
  </Components>
</ApplicationPackage>
Any help would be appreciated, as I am trying to roll this out ASAP to get everyone up and running with 2025 CAD with little to no problems for those who lag behind.
ActivistInvestor
You should nest RuntimeRequirements within ComponentEntry elements.  Having them at the same level is ambiguous. I recall the docs/examples originally showed it that way, but that's not correct.
  <Components>
     <ComponentEntry
	Version="24.0.1"
