ProgressBar C#
ProgressBar C#
k005
Advisor Advisor
Message 1 of 20
ProgressBar C#
k005
Hello
I'm running a code that saves the dwg files in the 2010 version.
I want to add a progressbar showing this job
How should I do the coding?
Thanks.
Replies (19)
Message 2 of 20
hippe013
Use the built in progress meter. Autodesk.AutoCAD.Runtime.ProgressMeter
https://through-the-interface.typepad.com/through_the_interface/2007/05/displaying_a_pr.html
 <CommandMethod("TestProgressMeter")>
    Public Sub CmdTestProgMeter()
        Dim pm As New ProgressMeter
        pm.Start("Processing...")
        pm.SetLimit(100)
        For i As Integer = 0 To 99
            System.Threading.Thread.Sleep(TimeSpan.FromSeconds(0.01))
            pm.MeterProgress()
            System.Windows.Forms.Application.DoEvents()
        Next
        pm.Stop()
    End Sub
Message 3 of 20
k005
Hi @hippe013
I want to make a Progressbar1 indicator on the form, not via AutoCAD cmd.
In other words, a conversion will be done and I want to see this process in progress.
How should I revise the codes?
Message 4 of 20
essam-salah
Hi @k005
If you use winForms try this examples example1 , example2
Message 5 of 20
hippe013
The progress bar that I showed you is the built-in progress bar that will show up in the AutoCAD UI. If you are looking to add a progress bar to a form then you would be using a Windows.Forms.Progressbar. Is this what you are need help with?
Message 6 of 20
k005
Hi @essam-salah
I ran the codes in example1. But the progressbar is 8 seconds up. The process took 20 seconds ...
Message 7 of 20
k005
Hi @hippe013
Yes, definitely.
There is a progressbar1 built on winform. I want to use this
Thanks.
Message 8 of 20
hippe013
It would much easier to help you if you posted your code rather than having people guess at the million things that could be going wrong.
Message 9 of 20
k005
@hippe013
 [CommandMethod("OPSV")]
        public  void KaydetToplu ()
        try
                Stopwatch watch = new Stopwatch();
                watch.Start();
                var path = @"C:\TestBack\";
                DirectoryInfo d = new DirectoryInfo(path);
                FileInfo[] Files = d.GetFiles("*.dwg");
                foreach (FileInfo file in Files)
                    var fileName = Path.GetFileName(file.FullName);
                    string dwgFlpath = path + fileName;
                  using (Database db = new Database(false, true))
                        db.ReadDwgFile(dwgFlpath, FileOpenMode.OpenForReadAndAllShare, false, null);
                        using (Transaction tr = db.TransactionManager.StartTransaction())
                            BlockTable bt = tr.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
                            BlockTableRecord btr = tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
                            using (Circle crcl = new Circle())
                                crcl.Center = new Point3d(1, 1, 0);
                                crcl.Radius = 2;
                                btr.AppendEntity(crcl);
                                tr.AddNewlyCreatedDBObject(crcl, true);
                            tr.Commit();
                        db.SaveAs(dwgFlpath, DwgVersion.AC1024);
                watch.Stop();
                Application.ShowAlertDialog("Tüm dosyalar 2010 Formatında Kaydedildi. Süre --»  " + watch.Elapsed.Seconds.ToString() + " sn");
            catch (System.Exception ex)
                Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(ex.ToString());
Message 10 of 20
k005
private void btn2010save_Click_2(object sender, EventArgs e)
            //CaluculateAll(progressBar1);
            Myc.KaydetToplu();
Message 11 of 20
hippe013
It appears that you haven't created your form yet. Is this the case?
Your command method should instantiate the form and then call ShowDialog and that is it really. Nothing else needed in your CommandMethod.
 [CommandMethod("TestProgressMeter")]
        public void CmdTestProgressMeter()
            MyProgressForm form = new MyProgressForm();
            form.ShowDialog();
Inside the form you might have a button that will start the process.  Here I call it button1. Also on the form is a ProgressBar and it is called progressBar1.
private void button1_Click(object sender, EventArgs e)
            var path = @"C:\MyPathToMyDWGFiles\";
            progressBar1.Maximum = Files.Length - 1;
            progressBar1.Minimum = 0;
                            crcl.Radius = 2;
                        tr.Commit();
                progressBar1.Increment(1);
Note:
1) C# is not my first language, but you should be able to get the idea from the above example.
2) I have not tested your code. Only showing how to setup progresssBar1 and then increment using your foreach loop.
3) I am assuming that you've created your form and added a ProgressBar and a Button.
I hope that this helps.
Message 12 of 20
k005
@hippe013
Thank you so much. All right. Progressbar works the way I want ...
Message 13 of 20
hippe013
Great to hear! I'm glad that I was able to  help.
Message 14 of 20
k005
@hippe013
            label1.Text= ?
How can I give the value of Label1%?
When all files are finished: 100%
Start: 0%
Message 15 of 20
hippe013
Just keep track of a counter and compute the percent complete.
int counter = 0;
int maxCount = Files.Length - 1;
// Your Process
counter += 1;
label1.Text = ((counter / maxCount) * 100).ToString() + "% Complete";
Message 16 of 20
k005
@hippe013
I added the codes. But it doesn't show instantly.
When finished, label1 = 100% Complete appears. Am I doing it wrong somewhere?
Message 17 of 20
hippe013
You may need to refresh. Though like I said, I haven't tested your code.
Try adding the DoEvents method.
label1.Text = (counter / maxCount).ToString() + "% Complete";
System.Windows.Forms.Application.DoEvents();
The DoEvents method should allow the window to update in the middle of the foreach.
Message 18 of 20
k005
@hippe013
It only writes the beginning and the end
when i press the button label1: 0% complete
When finished in a 100% complete.
no intermediate values.
Message 19 of 20
k005
                counter += 1;
                islem = ((counter * 100) / maxCount);
                label1.Text = islem.ToString() + "% Tamamlandı";
I managed to get intermediate values by changing the code in this way. But when it's done, it passes 100% ... 😞
Message 20 of 20
hippe013
It should be.
islem = ((counter / maxCount) * 100);
