How can I create custom entity with c#?
integtech
integtech
Hi, Dears.
I want to make a custom entity including line, circle and text.
Then, I want it to be saved and loaded in dwg file.
Is it possible in c# plugin project?
Could you give me a sample code or link for reference?
essam-salah
Hi @integtech
without Plugins i think Dynamic Blocks enough,
norman.yuan
Depending on in what context "custom entity" means: if you mean custom entities similar to the ones in AutoCAD verticals (C3D, Architecture...), such as Alignment, CogoPoint, Wall..., then no, you need to use ObjectARX C++ API to create that kind of custom entity.
With .NET API, the alternative to custom entity, sort of, is Overrule.
Norman Yuan
Drive CAD With Code
