tab when the text has a different size
I want to insert a Text, I almost succeeded in doing so, but since sometimes my text is a different size, they don't line up.
I enclose what I have, as well as my code
 [CommandMethod("TABULATION")]
        public static void Tab()
            CommandTemplates.ActionCall((Document doc, Editor ed, Database db, Transaction tr) =>
                Dictionary<string, int> ItemList = new Dictionary<string, int>();
                var T1 = new Dictionary<string, string>()
                    ["ALPHA"] = "1",
                    ["BETA"] = "2",
                    ["OMEGA"] = "3"
                var T2 = new Dictionary<string, string>()
                    ["ALPHA"] = "aaaaaaaaaaaaaaaaaaaaaaaaaa",
                    ["BETA"] = "bbbbbbbb",
                    ["OMEGA"] = "ccc"
                var T3 = new Dictionary<string, string>()
                    ["ALPHA"] = "they are not in the same colone",
                    ["BETA"] = "they are not in the same colone",
                    ["OMEGA"] = "they are not in the same colone"
                var mtext = new MText();
                mtext.Contents = string.Join("\\P", T1.Select(pair => pair.Key + "\t"+ T2[pair.Key] + "\t" + T3[pair.Key]));
                var A = mtext.Contents.ToString();
                CreateMText(A, ed);
essam-salah
Hi @Anonymous
try use string.PadRight() / string.PadLeft to align text Left/Right
essam-salah
@Anonymous
try this:
// Columns
                    ["ALPHA"] = "1",
                    ["BETA"] = "2",
                    ["OMEGA"] = "3"
                    ["OMEGA"] = "ccc"
                var WidthArr = new int[]
                    T1.Values.Select(s => s.Length).Max(),
                    T2.Values.Select(s => s.Length).Max(),
                    T3.Values.Select(s => s.Length).Max(),
                var table = string.Join("\n", T1.Keys.Select(key =>
                    $"{T1[key].PadRight(WidthArr[0])}\t" +
                    $"{T2[key].PadRight(WidthArr[1])}\t" +
                    $"{T3[key].PadRight(WidthArr[2])}"));
norman.yuan
I think the idea of trying to display single text string in a table/column style is bad idea: most text fonts do not have the fixed width for all characters, so unless your entire text string only uses a SINGLE character, there is no way to guarantee text entity's width of certain count of characters, whether you use "\t", or pad the string (left or right).
You might want to explain why you have to use a single MTEXT to display text string in a table/column style? Why do you not use multiple text entities so that you can position/align them what ever way you want to? Or you can define a block as a table row with attributes at each column position.
Norman Yuan
Drive CAD With Code
Hello @norman.yuan  & @essam-salah
thank you both, you helped me a lot
i have make this
mtext.Contents = string.Join("\\P", ItemList.Select(pair =>"\\pxt10, 48, 63;"  + pair.Key + "\t" + Designation[pair.Key] + "\t" + pair.Value + "\t" + Certificat[pair.Key] ));
But now, i want to modify the space between two lines. (modify my "\\P" value)
thanks a lot !
essam-salah
I don't Know what "\\P" means, but you can add new line by "\n"  or Environment.NewLine
norman.yuan
I am still skeptical on why you need to show data of rows/columns with a single MText entity. But for changing the space between lines of a MText, you can look into MText's properties: LineSpaceDistance, LineSpaceFactor and LineSpaceStyle.
Norman Yuan
Drive CAD With Code
