Problem with optional argument
Ed__Jobe
Mentor Mentor
Message 1 of 14
Ed__Jobe
Here is the signature of my method.
        public static void Redefine(this BlockReference blkRef, Transaction trans, string path, Blocks.RedefineAction flag, string blockname = "")
            string text = "";
            if (blockname == "")
                text = blkRef.Name;
If I call it without specifying the last optional argument, I get an invalid input error. If I call it with a string, it works, but if I call it with and empty string "" to get around the first error condition, I still get an invalid argument error. What am I missing? Thanks in advance.
Ed
How to post your code.
Replies (13)
Message 2 of 14
kerry_w_brown
I'd need to see your input Ed
This works for me ac2023 vs2022 4.8
    public class Commands
        private static Document _doc = AcadApp.DocumentManager.MdiActiveDocument;
        private static Database _db = _doc.Database;
        private static Editor _ed = _doc.Editor;
        [CommandMethod("TEST")]
        public static void Test()
            _ed.WriteMessage("Redefine Test\n");
            Redefine("");
            Redefine("", "oranges");
                            string path,
            string textValue = "something";
            //if (string.IsNullOrEmpty(blockname))
                textValue = "nothing";
            _ed.WriteMessage($"{textValue}\n");
I thought initially the issue may have been with the equality conditional, but it seems OK
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 3 of 14
Ed__Jobe
Well here are the scenarios:
// returns error
oldBlk.Redefine(trans, sTitleBlock, Blocks.RedefineAction.PreserveAttValues);
// returns erro
oldBlk.Redefine(trans, sTitleBlock, Blocks.RedefineAction.PreserveAttValues, "");
// No error
oldBlk.Redefine(trans, sTitleBlock, Blocks.RedefineAction.PreserveAttValues, "test");
Ed
Message 4 of 14
kerry_w_brown
Ed,
Would you happen to also have an overloaded version of that Method ??
Message 5 of 14
kerry_w_brown
FWIW :
Message 6 of 14
Ed__Jobe
No, I only have just the one method definition. I thought about using named parameters, but I thought it should work without it.
Ed
Message 7 of 14
Ed__Jobe
I tried the following and it still caused an error. Scratching my head. 😟
oldBlk.Redefine(trans: trans, path: sTitleBlock, flag: Blocks.RedefineAction.PreserveAttValues, blockname: "");
Ed
Message 8 of 14
Ed__Jobe
Below is what the signature looks like in the utility dll, but when I compile it, the referenced dll looks like the first post.
                                    Transaction trans,
                                    string path,
                                    [Optional] [DefaultParameterValue("")] string blockname)
            // store correct name
            string newName = "";
                //use filename as blockname
                //assume path is .dwg
                newName =  Path.GetFileName(path);
                newName = newName.Remove(newName.Length - 4);
 I modified this definition to get rid of the attribute tags and just assign a default value with (string blockname = ""), but this too still fails with invalid input error. The only thing I can see that I'm doing different from you is that this extension method is defined in a utility dll that is referenced into the solution.
Ed
Message 9 of 14
Norman_Yuan
with "string" type, null is not equal to "" (empty string). So, if you call the method with a string argument as optional and not passing anything, then that argument is null, not "". Now you can see why "if (blockname == "")' would raise error, because variable blockname is null: you cannot compare null to anything other than null.
The correct code should be
if (!string.IsNullOrEmpty(blockname)
Norman Yuan
Drive CAD With Code
Message 10 of 14
Ed__Jobe
Ok, I changed the logic of the if statement, but during debug, I can't even step into the redefine method. I still get the invalid input error. It never makes it to the logic test.
Ed
Message 11 of 14
Ed__Jobe
I'm still fighting with this optional argument. I thought it might be a problem with assigning the default value to an empty string, so I changed the default to null, but this errors too.
//calling sub
oldBlk.Redefine(trans: trans, path: sTitleBlock, flag: Blocks.RedefineAction.PreserveAttValues);
//method signature
       public static void Redefine(this BlockReference blkRef, Transaction trans, string path, Blocks.RedefineAction flag, string blockname = null)
            string text = "";
                text = Path.GetFileName(path);
                text = text.Remove(text.Length - 4);
Ed
Message 12 of 14
_gile
You should give more informations because there's nothing wrong in the extract of code you show.
What's the error?
Which expression causes this error?
Here's a little testing example which focus on the optional string argument:
        [CommandMethod("CMD1")]
        public static void Cmd1()
            OptionnalArgumentTest(@"B:\Desktop\Example.dwg");
        [CommandMethod("CMD2")]
        public static void Cmd2()
            OptionnalArgumentTest(@"B:\Desktop\Example.dwg", "SomeBlockName");
        static void OptionnalArgumentTest(string path, string blockName = null)
            string text = string.IsNullOrEmpty(blockName) ?
                Path.GetFileNameWithoutExtension(path) :
                blockName;
            Application.ShowAlertDialog(text);
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
Message 13 of 14
Ed__Jobe
It was a stupid simple omission. I left out the 'else' keyword and newName was getting reset to "". 😧
                                    Transaction trans,
                                    string path,
                newName =  Path.GetFileNameWithoutExtension(path);
            else //<<missing
                newName = blockname;
Ed
Message 14 of 14
kerry_w_brown
Ed,
I'm stumped too.
For me on  ac2023, vs2022, 4.8,
public static void OptionTest(
                    string path,
    string textValue = (string.IsNullOrEmpty(blockname)) ? "nothing" : "something";
    _ed.WriteMessage($"\n{textValue}\n");
// Test statements
    _ed.WriteMessage("Optional Parameter Test\n");
    OptionTest("YellowBrickRoad");
    OptionTest("YellowBrickRoad", "oranges");
    OptionTest("YellowBrickRoad", "");
    OptionTest("YellowBrickRoad", null);
Result :
What happens if you take something like this to a console app ??
added:
ahhh, it was resolved while I was composing this . . .  must learn to type faster 🙂
