Preview Window in AutoCAD using .NET API
Message 1 of 18
Hi everyone, I want to build the application such like that it shows preview in the GUI (User Interface) before it draw anything in the AutoCAD. Note that I want to create 3D objects in AutoCAD and if possible then preview window should be allow user to rotate the 3D objects using mouse in preview window. I hope this much is enough to understand my requirement. Thanks in advance.
Replies (17)
Message 2 of 18
FRFR1426
You can render to a picture box this way:
Manager gsm = doc.GraphicsManager;
using (var view = new View())
var cvport = (short)Application.GetSystemVariable("CVPORT"); doc.GraphicsManager.SetViewFromViewport(view, cvport); view.SetView(new Point3d(0, 0, 1), Point3d.Origin, Vector3d.YAxis, pictureBox.Width, pictureBox.Height); var descriptor = new KernelDescriptor(); descriptor.addRequirement(Autodesk.AutoCAD.UniqueString.Intern("3D Drawing")); GraphicsKernel kernel = Manager.AcquireGraphicsKernel(descriptor); Device dev = gsm.CreateAutoCADOffScreenDevice(kernel); using (dev) { dev.OnSize(pictureBox.Size); dev.DeviceRenderType = RendererType.Default; dev.BackgroundColor = Color.White; dev.Add(view); dev.Update(); try { using (Model model = gsm.CreateAutoCADModel(kernel)) { var extents3D = new Extents3d(); var line = new Line(p1, p2); [..] view.Add(line, model); extents3D.AddExtents(line.Bounds.Value); view.ZoomExtents(extents3D.MinPoint, extents3D.MaxPoint); view.Zoom(0.9); } pictureBox.Image = view.GetSnapshot(new Rectangle(0, 0, pictureBox.Width - 1, pictureBox.Height - 1)); finally { view.EraseAll(); dev.Erase(view); if (null != line) line.Dispose(); } } }
Maxence DELANNOY
Manager
Add-ins development for Autodesk software products
http://wiip.fr
Message 3 of 18
Thanks for your help...! Just one question will I be able to rotate objects in picture box through Mouse?
Message 4 of 18
FRFR1426
No this code is for a static preview. To get orbit functionality, you'll need to write a custom control which will handle the mouse movements and call view.Orbit to update the view.
Maxence DELANNOY
Manager
http://wiip.fr
Message 5 of 18
dgorsman
A slightly sideways but less development-intensive option may be to generate a temporary 3D DWF and then pass it to a separate Design Review or Navisworks Freedom session; there might also be the option to embed a Navisworks viewer object.  All the navigation tools, none of the labor.
Message 6 of 18
FRFR1426
http://through-the-interface.typepad.com/through_the_interface/2008/06/autocad-net-ver.html
Maxence DELANNOY
Manager
http://wiip.fr
Message 7 of 18
FRFR1426
Here is a complete control:
using System;
using System.Drawing;
using System.Windows.Forms;
using Autodesk.AutoCAD;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.GraphicsSystem;
using Application = Autodesk.AutoCAD.ApplicationServices.Application;
using View = Autodesk.AutoCAD.GraphicsSystem.View;
namespace TestCS
    public partial class PreviewUserControl : UserControl
        #region Fields
        Device device;
        Extents3d extents;
        Model model;
        Solid3d solid;
        Point start;
        View view;
        #endregion
        #region Constructors
        public PreviewUserControl()
            InitializeComponent();
            SetStyle(ControlStyles.UserPaint | ControlStyles.AllPaintingInWmPaint, true);
        #endregion
        #region Methods
        void CleanUp()
            if (solid != null)
                solid.Dispose();
                solid = null;
            if (model != null)
                model.Dispose();
                model = null;
            if (view != null)
                // View need to be removed from device
                device?.EraseAll();
                view.Dispose();
                view = null;
            if (device != null)
                device.Dispose();
                device = null;
        protected override void CreateHandle()
            base.CreateHandle();
            if (DesignMode) return;
            Document doc = Application.DocumentManager.MdiActiveDocument;
            descriptor.addRequirement(UniqueString.Intern("3D Drawing"));
            device = gsm.CreateAutoCADDevice(kernel, Handle);
            device.OnSize(Size);
            view = new View();
            view.SetView(new Point3d(1, 1, 1), view.Target, view.UpVector, view.FieldWidth, view.FieldHeight);
            device.Add(view);
            model = gsm.CreateAutoCADModel(kernel);
            extents = new Extents3d();
            solid = new Solid3d();
            solid.CreateBox(1, 1, 1);
            solid.ColorIndex = 1;
            view.Add(solid, model);
            if (solid.Bounds != null) extents.AddExtents(solid.Bounds.Value);
            HandleDestroyed += PreviewUserControl_HandleDestroyed;
        protected override void OnMouseDoubleClick(MouseEventArgs e)
            base.OnMouseDoubleClick(e);
            view.ZoomExtents(extents.MinPoint, extents.MaxPoint);
            RefreshView();
        protected override void OnMouseDown(MouseEventArgs e)
            base.OnMouseDown(e);
            start = e.Location;
        protected override void OnMouseMove(MouseEventArgs e)
            base.OnMouseMove(e);
            if (e.Button != MouseButtons.Left) return;
            view.Orbit(Math.PI * (start.X - e.X) / Width, Math.PI * (e.Y - start.Y) / Height);
            start = e.Location;
            RefreshView();
        protected override void OnPaint(PaintEventArgs e)
            RefreshView();
        protected override void OnSizeChanged(EventArgs e)
            base.OnSizeChanged(e);
            device?.OnSize(Size);
            RefreshView();
        void PreviewUserControl_HandleDestroyed(object sender, EventArgs e)
            CleanUp();
        void RefreshView()
            if (view == null) return;
            view.Invalidate();
            view.Update();
        #endregion
Maxence DELANNOY
Manager
http://wiip.fr
Message 8 of 18
Hi, I am not able to build the Application due to KernelDescriptor. var descriptor = new KernelDescriptor(); 1. May I know which references I have to add for KernelDescriptor? Is this class belonging to AutoCAD APIs or Microsoft(Visual Studio) APIs ? 2. This code is for AutoCAD .NET API not for ObjectARX. Am I Right ?
Message 9 of 18
FRFR1426
KernelDescriptor is for AutoCAD 2015 and more. Before that, you only need to pass the window handle to the CreateAutoCADDevice method:
device = gsm.CreateAutoCADDevice(Handle);
1. KernelDescriptor is in the Autodesk.AutoCAD.GraphicsSystem namespace (Acdbmgd.dll). It's an AutoCAD API.
2. It's for .NET API, not for ObjectARX (C++) API
Maxence DELANNOY
Manager
http://wiip.fr
Message 10 of 18
Bonjour, Je viens d'utiliser votre exemple (super au passage), et j'aimerai après l'orbite pouvoir revenir à une vue de dessus... sans succès. :(( Cordialement.
Message 11 of 18
FRFR1426
Pour les vues standards (ortho/isométrique), il faut utiliser la méthode SetView qui permet de repositionner la caméra. Pour une vue de dessus (vue du plan XY), ça donne ça :
view.SetView(view.Target + Vector3d.ZAxis, view.Target, Vector3d.YAxis, view.FieldWidth, view.FieldHeight);
On conserve la cible et les dimensions du champ de vue, on positionne la caméra juste au dessus de la cible et on réaligne le haut de la caméra avec l'axe Y.
Maxence DELANNOY
Manager
http://wiip.fr
Message 12 of 18
Merci pour votre réponse.
Cordialement.
Patrick.
Message 13 of 18
Do I lack of some namespace or class KernelDescriptor is a new one?
Message 14 of 18
norman.yuan
If you read through the thread carefully, you'd have seen it:
FRFR1426 answered it on 09-16-2015: The name space is Autodesk.AutoCAD.GraphicsSystem (in acdbmgd.dll).
Norman Yuan
Drive CAD With Code
Message 15 of 18
kerry_w_brown
 @Anonymous
I think Norman means Post 9 of 14
The dates displayed are expressed in local time and may differ for readers in differing locations.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Message 16 of 18
How do you incorporate 'LineWeight' on this?
I wanted to adapt this on our app's preview window, and I wanted to add a feature where an object appears to be highlighted (in a sense that the line weight would appear bolder) on the snapshot.
Message 17 of 18
A_Taha
Thanks for the control, it works great. Is it possible to add zoom-in and zoom-out functionality with the mouse wheel?
A. Taha
Message 18 of 18
_gile
You can override the OnMouseWheel event handler.
        protected override void OnMouseWheel(MouseEventArgs e)
            base.OnMouseWheel(e);
            if (0 < e.Delta)
                view.Zoom(1.6);
            else
                view.Zoom(0.625);
            RefreshView();
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
