Plot Script not working. Need help
Hi Guys,
I have been working on this plot script for a while now and I had it working at one time but now it does not seem to work.  It is giving me errors in random places depending on the instance.  I am getting errors on the units line.  I have indicated where my errors are.  They are not consistant.  It will show in one spot at runtime now, and another at runtime later.  Need help.  Thanks in advance.
Heres the code.
<CommandMethod("MB_PlotAllTabs")> _
    Public Sub MB_PlotAllTabs()
        Dim LayoutPlotSettings As String()
        Dim LayoutName As String
        Dim PageSize As String
        Dim PageName As String
        Dim PltOrientation As String
        'Get current list of tabs in order
        Dim myTabList As SortedDictionary(Of Integer, String).ValueCollection = MB_LayoutTabList()
        '' Get the current document and database, and start a transaction
        Dim acDoc As Document = Application.DocumentManager.MdiActiveDocument
        Dim acCurDb As Database = acDoc.Database
        Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
            '' Reference the Layout Manager
            Dim acLayoutMgr As LayoutManager
            acLayoutMgr = LayoutManager.Current
            For Each TabName In myTabList
                'Get plotsettings from current layout
                LayoutPlotSettings = MB_DeterminePlotSettings()
                LayoutName = LayoutPlotSettings(0)
                PageSize = LayoutPlotSettings(1)
                PageName = LayoutPlotSettings(2)
                PltOrientation = LayoutPlotSettings(3)
                'Get Default Plot Settings from XML File
                If PageName = "default" Then
                    PageName = "dsize"
                End If
                Dim DefPrinterName As String = CoreClass.GetXMLSetting("printersettings", PageName, "printername")
                Dim DefPaperName As String = CoreClass.GetXMLSetting("printersettings", PageName, "papername")
                Dim DefUnits As String = CoreClass.GetXMLSetting("printersettings", PageName, "units")
                Dim DefScale As String = CoreClass.GetXMLSetting("printersettings", PageName, "scale")
                Dim DefOffset As String = CoreClass.GetXMLSetting("printersettings", PageName, "offset")
                Dim DefOrient As String = CoreClass.GetXMLSetting("printersettings", PageName, "orientation")
                Dim DefPlotStyle As String = CoreClass.GetXMLSetting("printersettings", PageName, "plotstyle")
                MsgBox(LayoutName, MsgBoxStyle.OkOnly)
                MsgBox(PageSize, MsgBoxStyle.OkOnly)
                MsgBox(PageName, MsgBoxStyle.OkOnly)
                MsgBox(PltOrientation, MsgBoxStyle.OkOnly)
                MsgBox(DefPrinterName, MsgBoxStyle.OkOnly)
                MsgBox(DefPaperName, MsgBoxStyle.OkOnly)
                MsgBox(DefUnits, MsgBoxStyle.OkOnly)
                MsgBox(DefScale, MsgBoxStyle.OkOnly)
                MsgBox(DefOffset, MsgBoxStyle.OkOnly)
                MsgBox(DefOrient, MsgBoxStyle.OkOnly)
                MsgBox(DefPlotStyle, MsgBoxStyle.OkOnly)
                'make array of offset points, need to convert to double on use
                Dim OffsetPoints As String() = DefOffset.Split(New Char() {","c})
                'Get the current layout
                Dim acLayout As Layout
                acLayout = acTrans.GetObject(acLayoutMgr.GetLayoutId(LayoutName), OpenMode.ForRead)
                'Get the PlotInfo from the layout
                Dim acPlInfo As PlotInfo = New PlotInfo()
                acPlInfo.Layout = acLayout.ObjectId
                'Get a copy of the PlotSettings from the layout
                Dim acPlSet As PlotSettings = New PlotSettings(acLayout.ModelType)
                acPlSet.CopyFrom(acLayout)
                'Update the PlotSettings object
                Dim acPlSetVdr As PlotSettingsValidator = PlotSettingsValidator.Current
                '////////////////// Begin configuration ////////////////
                'Set the plot type
                acPlSetVdr.SetPlotType(acPlSet, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents)
                'Set the plot scale
                acPlSetVdr.SetUseStandardScale(acPlSet, True)
                'acPlSetVdr.SetCustomPrintScale(acPlSet, CustomScale)
                acPlSetVdr.SetStdScaleType(acPlSet, StdScaleType.StdScale1To1)
                'Set the offsets (always takes default from XML)
                acPlSetVdr.SetPlotCentered(acPlSet, False)
                acPlSetVdr.SetPlotOrigin(acPlSet, New Point2d(CType(OffsetPoints(0), Double), CType(OffsetPoints(1), Double)))
                'Set the paper units (always takes default from XML)
                If DefUnits = "Millimeters" Then
                    acPlSetVdr.SetPlotPaperUnits(acPlSet, PlotPaperUnit.Millimeters)
                Else
                    acPlSetVdr.SetPlotPaperUnits(acPlSet, PlotPaperUnit.Inches)'<-----HAD AN ERROR HERE
                End If
                'Set the paper orientation rotation (use dynamic if not default)
                If Not PageName = "default" Then
                    If PltOrientation = "Landscape" Then
                        acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees000)
                    Else
                        acPlSetVdr.SetPlotRotation(acPlSet, PlotRotation.Degrees090)
                    End If
                Else
                    If DefOrient = "Landscape" Then
                    Else
                    End If
                End If
                'Set the plot device to use
                acPlSetVdr.SetPlotConfigurationName(acPlSet, "DWG To PDF.pc3", "ANSI A (8.50 x 11.00 Inches)")
'<----HAD CONSISTANT ERRORS HERE, I REPLACED MY VARS WITH HARD STRINGS TO DEBUG
                '' Set the plot info as an override since it will
                '' not be saved back to the layout
                acPlInfo.OverrideSettings = acPlSet
                '' Validate the plot info
                Dim acPlInfoVdr As PlotInfoValidator = New PlotInfoValidator()
                acPlInfoVdr.MediaMatchingPolicy = MatchingPolicy.MatchEnabled
                acPlInfoVdr.Validate(acPlInfo)
                '' Check to see if a plot is already in progress
                If PlotFactory.ProcessPlotState = Autodesk.AutoCAD.PlottingServices.ProcessPlotState.NotPlotting Then
                    Using acPlEng As PlotEngine = PlotFactory.CreatePublishEngine()
                        '' Track the plot progress with a Progress dialog
                        Dim acPlProgDlg As PlotProgressDialog = New PlotProgressDialog(False, 1, True)
                        Using (acPlProgDlg)
                            '' Define the status messages to display when plotting starts
                            acPlProgDlg.PlotMsgString(PlotMessageIndex.DialogTitle) = "Plot Progress"
                            acPlProgDlg.PlotMsgString(PlotMessageIndex.CancelJobButtonMessage) = "Cancel Job"
                            acPlProgDlg.PlotMsgString(PlotMessageIndex.CancelSheetButtonMessage) = "Cancel Sheet"
                            acPlProgDlg.PlotMsgString(PlotMessageIndex.SheetSetProgressCaption) = "Sheet Set Progress"
                            acPlProgDlg.PlotMsgString(PlotMessageIndex.SheetProgressCaption) = "Sheet Progress"
                            '' Set the plot progress range
                            acPlProgDlg.LowerPlotProgressRange = 0
                            acPlProgDlg.UpperPlotProgressRange = 100
                            acPlProgDlg.PlotProgressPos = 0
                            '' Display the Progress dialog
                            acPlProgDlg.OnBeginPlot()
                            acPlProgDlg.IsVisible = True
                            '' Start to plot the layout
                            acPlEng.BeginPlot(acPlProgDlg, Nothing)
                            '' Define the plot output
                            acPlEng.BeginDocument(acPlInfo, acDoc.Name, Nothing, 1, False, Nothing)
'<----HAD AN ERROR HERE
                            '' Display information about the current plot
                            acPlProgDlg.PlotMsgString(PlotMessageIndex.Status) = "Plotting: " & acDoc.Name & " - " & TabName
                            '' Set the sheet progress range
                            acPlProgDlg.OnBeginSheet()
                            acPlProgDlg.LowerSheetProgressRange = 0
                            acPlProgDlg.UpperSheetProgressRange = 100
                            acPlProgDlg.SheetProgressPos = 0
                            '' Plot the first sheet/layout
                            Dim acPlPageInfo As PlotPageInfo = New PlotPageInfo()
                            acPlEng.BeginPage(acPlPageInfo, acPlInfo, True, Nothing)
                            acPlEng.BeginGenerateGraphics(Nothing)
'<-------HAD AN ERROR HERE                            acPlEng.EndGenerateGraphics(Nothing)
                            '' Finish plotting the sheet/layout
                            acPlEng.EndPage(Nothing)
                            acPlProgDlg.SheetProgressPos = 100
                            acPlProgDlg.OnEndSheet()
                            '' Finish plotting the document
                            acPlEng.EndDocument(Nothing)
                            '' Finish the plot
                            acPlProgDlg.PlotProgressPos = 100
                            acPlProgDlg.OnEndPlot()
                            acPlEng.EndPlot(Nothing)
                        End Using
                    End Using
                End If
            Next
        End Using
        'Clear Settings
        LayoutPlotSettings = Nothing
        LayoutName = Nothing
        PageSize = Nothing
        PageName = Nothing
        PltOrientation = Nothing
    End Sub
Without emplementing your code:
  1. What the errors that it calls out? (null, nothing found, not applicable, etc...)
  2. ARE YOU ABSOLUTELY SURE your strings for the PC3 file and other namse (PAPER NAME) are correct?  I once found that when printing to an HP Plotter, the paper names shown on screen, and the ones used in code are different.  Write a for each loop to display the paper names found and match them up, just to be sure.
Side Note:
You can use "Debug.Print (something)" instead of MsgBox to get it in your Immediate Window, and not stop the code with a bunch of OK buttons.
jvj
