Plant 3D API/C# Question
jmartensBGRRW
jmartensBGRRW
Hello!
I am new to AutoCAD Plant 3D/API/C# and have been trying to go thru examples and came across
Autodesk Developer Network - Plant3D Training Material. My question is from Lab_04 and I have attached a zip file with the code in a text file for your reference.
I am stuck trying to access the "LineNumberTag". I can see the LineNumberTag information ("INTOCAD001") while running in debug mode, but it shows up in a "Dynamic View" and I am not sure how to access it using C# code.
I took some screenshots of what I am looking at in the hopes that it will resonate with someone that will be able to assist me.
Thank you for your help and time in advance!
daniel_cadext
could be properties using C#'s dynamic keyword, I don't have much experience with it, here's my first attempt
at goofing around with it, maybe will give you inspiration.
https://www.theswamp.org/index.php?topic=55916
Python for AutoCAD, Python wrappers for ARX https://github.com/CEXT-Dan/PyRx
jabowabo
You can retrieve all part properties, including LineNumberTag, using DataLinksManager.GetAllProperties.
jmartensBGRRW
Hi Daniel!
Thank you for your suggestion. I was looking at taking the "dynamic" approach, but I discovered it was a little over my head.
jmartensBGRRW
Hi Jason,
Thank you very much for posting the DataLinksManager.GetAllProperties information.
I actually did try searching on the AutoCAD DevBlog website but did not have any luck.
