PCEXTRACTCENTERLINE Point Cloud feature recognition
madpanda
madpanda
AutoCAD 2015 (Vanilla) had a great plugin that would let you select parts of a pointcloud, and it would recognize cylinders and create solids. Well it's not available after 2015. But in 2017 there is a new Autodesk tool  PCEXTRACTCENTERLINE ! when you use it, you can see it recognizes the cylinder and creates a centerline. I am sure there isn't a way in VBA (what I am most comfortable with) But is there a way I can use PCEXTRACTCENTERLINE in .net to leave the cylinder that autocad temporary creates? see attached photo (transparent purple)
moogalm
Autodesk Support
Autodesk Support
 Sorry there is no API.
ActivistInvestor
You might try creating a DrawableOverrule targeting the Solid3d class, and see what pops up in WorldDraw() and ViewportDraw(). If you find the cylinder, you may be able to Clone() it.
